Oil Archive (no new posts) An archive of oil related questions and comments.
Oil Filter Wrench
Old Jan 28, 2006 | 03:45 AM
mkink's Avatar
mkink
Default Oil Filter Wrench
Where can I find an oil filter wrench that fits the end of the filter. I have the banded oil filter wrench and I think its a PITA to use. Any other suggestions would be helpful also. Thanks
Old Jan 28, 2006 | 05:56 AM
Tiffy's Avatar
Tiffy
Default RE: Oil Filter Wrench
You should be able to get the proper size oil filter wrench at the dealer. It fits over the end of the filter and is untightened with a simple ratchet. It's very easy to use, unlike the band type.
Old Jan 28, 2006 | 09:47 AM
HDF Tech's Avatar
HDF Tech
You can get it at the dealer or the local auto store. Get the standard one that fits the filter and you can use a grinding wheel to relieve the opening for the crank shaft sensor like pictured. It will cost less than half this way than it does at the dealer.
[IMG]local://upfiles/2318/F50A17D539A04ECBB180BBE82CD5F3F7.jpg[/IMG]
Old Jan 28, 2006 | 11:47 AM
BirchwhiteHD's Avatar
BirchwhiteHD
I'm using a filter wrench I have in the tool box from when i had toyota pickups, think it's a KD tool,cam action type ,extension and a ratchet ,as it's turned to take filter off it tightens the two jaws and grabs the end of the filter.no clearance problems with crank sensor
Old Jan 28, 2006 | 09:20 PM
Rodent's Avatar
Rodent
I made one of these useing a piece of 1/2" pipe and an old strap. I drilled a hole in the end to stick a phillips screwdriver through for the handle instead of a ratchet. I use it on my F-350 Diesel and have used it at my friends Harley shop when all other filter wrenches failed. One sive fits ALL.
http://www.lislecorp.com/tool_detail.cfm?detail=1113
Old Jan 30, 2006 | 10:42 AM
Woodyheritage's Avatar
Woodyheritage
I use a good strap type (rubber not metal banding). I works fine around the crank position sensor and enables me to use an extension to keep the wrenches off my frame and controls. I've used this since I purchased my 03 heritage in 03. Harley charges a lot for theirs. But if you are creative buy a filter, go to autozone and buy the full cap unit, get out the dremmel and cut away the amount you see in most of the descriptions. I like the belt idea because if nothing else I have enough vehicles I can use it on without having to buy anymore wrenches. Good luck,
Woody
Old Feb 4, 2006 | 10:37 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I just bought on with the sensor cut out from my dealer today for $9.00 KB[sm=smiley20.gif]
Old Feb 11, 2006 | 01:16 AM
Harley Al's Avatar
Harley Al
Take a look at the K&N filters...you need a socket to remove them, and they come in chrome also!
Good Luck!
Ride Safe!
Old Feb 24, 2006 | 03:28 AM
rjg883c's Avatar
rjg883c
ORIGINAL: mkink
I bought a wrench that fits on the end of the filter today at Pep Boys. It was $2.99.
Old Feb 25, 2006 | 12:30 AM
d42s's Avatar
d42s
ORIGINAL: TCSTD
I saw one like this at my dealer on the weekend was only $28.00.
Went to Wally and got one for $7, ground it out like the quote and money left over for beer.
Thanks
claytonandson
General Topics/Tech Tips
Apr 14, 2015 03:16 PM
dweez
Aug 30, 2014 11:37 AM
louie c
Oct 15, 2013 10:18 PM
mjaw
Jun 23, 2009 07:16 PM
SkipB
Jan 29, 2008 07:57 PM
