Oil Archive (no new posts) An archive of oil related questions and comments.
What Type of Oil
Old May 19, 2009 | 04:02 AM
1peter's Avatar
1peter
Default What Type of Oil
Does anyone know why everyone seems to think its ok to use GL5 rated oil in the transmission of a twin cam 88 motor. The only info I can find in the owners manual is the part number for the oil that should be used, 99891-84 or 99892-84 and both of these only tell you if it is semi syn (syn 3) or mineral oil (HD 360) ?? So where does the info about GL ratings and viscosities for H.D. Motorcycles come from??
__________________
peter
Old May 19, 2009 | 02:27 PM
V2Evo96's Avatar
V2Evo96
peter, you may want to have a look here for the different GL grades and the areas of use.
http://en.wikipedia.org/wiki/Gear_oil
I use various good quality gear oils in the 75-90 wt range (depending on price at the time) for my Evo trannys in which HD says Syn 3 is fine as well as for twin cams.
Valvoline makes a semi syn brand called DuraGear which is well priced here in Australia and works fine for me. Any good quality shear stable gear oil will do the job nicely.
I wouldn't use pricey Syn 3, when with a bit of research you will find as good or better for less $$$.
Just my thoughts--
V2
Old May 19, 2009 | 04:55 PM
1peter's Avatar
1peter
Thanks V2 EVO96.
Old May 19, 2009 | 07:59 PM
kromdom's Avatar
kromdom
wow, peter...3rd thread about oil??
just razzin you, mate
Old May 19, 2009 | 10:10 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
__________________
peter
Hd doesn't put API specs in their publications because they want you to buy only their products when their products are very expensive and only average in quality. HD Formula+ is a 50w oil with a weak additive package. You can buy Mobil1 Synthetic 75w90 GL5 gear oil for about the same price. You can get dino GL5 gear lube at any auto parts store for about $5/qt which will out perform Formula+
Old May 20, 2009 | 12:33 AM
1peter's Avatar
1peter
Mobil 1 75-90 would be my choice but in Australia you can only buy it in 20 litre drums.
Old May 20, 2009 | 10:29 AM
KBFXDLI's Avatar
KBFXDLI
Just look on any 75w90 or 80w90 or 75w140 oil container in your auto parts store and if it says GL5 you are good to go.
Old May 22, 2009 | 12:50 AM
V2Evo96's Avatar
V2Evo96
[quote=1peter; Mobil 1 75-90 would be my choice but in Australia you can only buy it in 20 litre drums.[end quote]
Hi Peter, I used to run this in my '96 Special-- really nice lube but pricey. I adopted the policy a while back of "change motor oil; change primary fluid" and as I change fluids at 3000ks (approx 2000 miles) I went back to dino fluids W/ exception of the tranny where I run semi-syn valvoline 75-90 and change at 6000ks.
Cheers,
V2
The Baron
Sep 11, 2020 09:50 AM
1peter
May 19, 2009 09:46 PM
1peter
Jun 5, 2007 10:30 PM
ROADRAGE98
Apr 5, 2006 08:33 AM
Lev
Aug 7, 2005 10:17 AM
