Oil Archive (no new posts) An archive of oil related questions and comments.
top end noise
Old May 19, 2006 | 03:23 PM
klemmer's Avatar
klemmer
Default top end noise
I have a 06 ultra. When cruising at highway speeds when i excellerate slightly i get a lot of top end noise, i was wondering if i switch to mobile 1 if that might help. Running on harley oil now. 2500 miles on the bike.....stage 1 with s/e performance mufflers and harley download. Runs great otherwise. Thanks in advance for any info.
Old May 19, 2006 | 07:19 PM
vernh59's Avatar
vernh59
Default RE: top end noise
The TC motor clatters some under hard accel. Mostly valve train noise. You didn't say where you are or what the temps are running BUT...... Mobile 1 helped mine a bit. At least it seemed to when I switched from Syn3. I would think the same would be true with HD Dino oil.
Old May 19, 2006 | 11:47 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I get the same thing with syn3......so go to the Mobil1Vtwin20w50 and it should help. When you get over 3000 miles you can use redline 20w50 or 20w60 synthetic.
Old May 20, 2006 | 11:09 PM
Square Dude's Avatar
Square Dude
I will just let my signature information be my comment on this. Otherwise someone will come running to make excuses for H-D.
Old May 22, 2006 | 04:14 PM
100thRK's Avatar
100thRK
Damn twin cams are just noisy. Used to drive me nuts. Calmed down quite a bit after I went into the motor and adjustable pushrods helped.
Old Road Toad
Apr 3, 2014 01:31 PM
trike1
20
Sep 13, 2013 07:41 PM
kimwest52
Jul 13, 2012 03:46 PM
2007rkjb
Jan 21, 2011 01:32 PM
ekcivic1
Nov 11, 2008 08:48 PM
