Oil Archive (no new posts) An archive of oil related questions and comments.
Thickest oil
Old Mar 28, 2010 | 01:00 PM
jbnl163's Avatar
jbnl163
Default Thickest oil
What would be the thickest engine oil I can use in a 2005 Twin Cam with over 44K on it? I run mostly in high temp - desert areas.
Old Mar 28, 2010 | 08:44 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Redline makes a 20w60. They were selling it on amazon for a while.
Old Mar 28, 2010 | 09:47 PM
Jim Kraft's Avatar
Jim Kraft
You can run HD 360 dino 60 wt.
Old Mar 29, 2010 | 10:00 AM
big cahuna's Avatar
big cahuna
Straight 60 wt is what the book calls for, for temps over 80 f. They make a straight 70 wt oil , but it's not recommended or spec'd for any modern motor I know of.,,
Old Mar 29, 2010 | 11:50 AM
Jim Kraft's Avatar
Jim Kraft
70 wt. is really hard to find now. I know Castrol, Kendall, and Valvoline still make it, but no one seems to stock it anymore. I mix it with gasoline to run in my old spark ign. model airplane engines from the 30's and 40's. When I can't find 70 wt., I use Harley 60 wt.. Harley use to make 70 wt HD360, but I have not seen any for several years.
Old Mar 29, 2010 | 12:22 PM
KBFXDLI's Avatar
KBFXDLI
Brad Penn makes "Nitro 70" a 70w oil. Not hard to get. But then 70w is way overkill.
Old Mar 29, 2010 | 12:25 PM
KBFXDLI's Avatar
KBFXDLI
Old Mar 29, 2010 | 12:55 PM
2Sore's Avatar
2Sore
Old Mar 29, 2010 | 02:41 PM
stevent's Avatar
stevent
I'd still use 20w50, it'll circulate through the engine faster and carry off more heat.
Old Mar 29, 2010 | 10:22 PM
KBFXDLI's Avatar
KBFXDLI
+1 I am in Ohio...but if I was in the SW I would use the redline 20w60.
