Oil Archive (no new posts) An archive of oil related questions and comments.
When to change oil
Old Sep 13, 2010 | 11:57 AM
sevenrider's Avatar
sevenrider
Stage II
Default When to change oil
Just purchased a 2010 Fatboy Lo.
Purchased by 1st owner Aug 2010.
He did the 1st service at 600 mi at which time he put V&H pipes and had it on the dyno for tuning done on 9/23/2010
It now has 1300 mi so that service was done alittle over a year ago.
I want to make sure I'm good warrenty wise and properly maintaning the bike.He used SYN oil should I change it prior to winter storage?Or just let it go for 5000 and service it then?Thanks for any help! Mark
Old Sep 13, 2010 | 12:58 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
I think you mean 2009 on the dyno not 10 days from now?
Yes, change the oil before layup. You should never let oil sit in an engine more than 1 year because it loses it's anti-corrosion ability (TBN) due to the acid build up of corrosion by products. Especially with a low mileage bike. I would change all 3 holes. If you refill the trans with Synthetic 75w90 gear oil like Mobil1 you can go a few years or 20,000 miles just checking it every month for any water intrusion from washing/rain etc. But the engine is 1 year or 5000 miles.
If you do your own service, get a cheap notebook and make a log of date/mileage/service and keep all the receipts for oil and filters etc. Best to use a HD filter and a Motorcycle rated oil. If you have a dealer do it then you are covered but keep your receipts.
Old Sep 13, 2010 | 01:02 PM
Iceman24's Avatar
Iceman24
Yep, ride away until you reach 5K miles, or winter storage (whichever comes 1st). Never want to hibernate on old oil & make sure you get a bettery tender to keep it topped off during storage: http://batterytender.com/
Shop around on the the internet b/c these can go as cheap as under $20...
Old Sep 13, 2010 | 01:12 PM
inaroush's Avatar
inaroush
Best advise is a little maintenance will help go a long long way.
I personally would change the oil before layup for winter sleep.
I just picked up my 2010, just broke 365 miles..... I figure by the time I put to sleep for winter I will have about 700 miles on her - she will be dealer maintained.
Keep all documents, a well documented serviced bike is worth more on resale than one which is not.
Old Sep 13, 2010 | 08:56 PM
sevenrider's Avatar
sevenrider
Stage II
my mistake I ment 2009,thanks for the tips I did my own maint. on my 2000 R/K I think I'll just use the dealer prior to winter storage.
bravozulu
Apr 26, 2017 11:41 PM
harley7316
Jan 7, 2014 08:04 AM
saibaba
Apr 12, 2011 11:55 AM
Lutzinator
Mar 9, 2011 06:30 AM
GymChamp
Nov 17, 2009 03:52 PM
