I've got an '03 Fat Boy with a fuel injected twin cam 88, it has an Screaming Eagle stage 1 intake with a K&N air filter, V&H Longshots with the standard baffles, and the ECU has been flashed with the 32830-01/DT 1450 down load.
I recently installed a temperature sensing dip stick on the oil tank. After a highway run with speeds averaging between 65 and 75 mph I see that my oil is running at 195° F.
Is this within acceptable temperature range, or is it running too hot....
Air temp at time of this run was 80° F......
Oil is Mobile 1 V-Twin 20W-50.....
200 and under are good oil temps...
I just have an old EVO and run Mobil 1 V-Twin Syn 20W50...
A couple of weeks ago it was 94 here and on a 60 mile trip in the middle
of the day the Oil temp was right at 240-245...I just have a regular dipstick style thermometer...over 250 and I park it...
M1Vtwin can go over 300f before it begins to oxidize. 250f wont hurt it.
