Oil Archive (no new posts) An archive of oil related questions and comments.
Should I remove primary chaincase cover?
Old Oct 2, 2012 | 07:23 PM
lawman1841's Avatar
lawman1841
6th Gear
Default Should I remove primary chaincase cover?
I'm about to change the fluids in my 07 Ultra for the first time and I'm going from HD Syn3 to Amsoil 20w-50.
The service manual says to add 38 oz. to the primary after draining with the drain plug but that 45 oz. is needed after the primary chaincase cover is removed. That indicates to me that 7 oz. of the HD Syn3 will be left in the primary if I only pull the drain plug.
Assuming I'm right, will it hurt anything if I put the Amsoil on top of that little bit of HD or should I go ahead and pop the cover to get the last of the HD out?
Thanks in advance.
Old Oct 2, 2012 | 07:29 PM
soft 02's Avatar
soft 02
Thanks in advance.
No worries. They will mix just fine.
Old Oct 2, 2012 | 07:37 PM
smitty901's Avatar
smitty901
Just change it do not remover the primary cover . The small amount is meaningless
And opening the cover could cause leaks or other issues just no worth it.
Old Oct 2, 2012 | 08:19 PM
lawman1841's Avatar
lawman1841
6th Gear
Thanks, guys.
Old Oct 2, 2012 | 10:25 PM
doc ock's Avatar
doc ock
Mity Vac and suck out the rest.
Pbjohns
Sep 9, 2013 09:41 PM
shanvhere
Oct 6, 2012 03:46 PM
rcracerk2
Jul 26, 2012 07:58 AM
ecoli
Mar 3, 2008 04:36 PM
catken
Dec 21, 2007 05:28 PM
