Oil Archive (no new posts) An archive of oil related questions and comments.
primary fluid Q
Old Mar 17, 2013 | 12:57 PM
noeld's Avatar
noeld
Default primary fluid Q
i was planing on running ATF in my 89 primary,& was told to run type F but not dexron III but when i looked at the bottles marked ATF they said that they were made for dexron-mercon cars so can i use this stuff or just type F ???
Old Mar 17, 2013 | 04:28 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Some clutch manufacturers may specify a certain type of ATF.
Type F ATF fluid is a non interchangeable spec.
If the manufacturer specifies type F, then there is no substitute, the container must say TYPE F. If you can`t find it at your local auto parts store, you can find it at the local Ford dealership.
If you aren`t required to use type f, you can use any type you want.
The easiest way to chose: use the same type as your car or truck uses.
Old Mar 17, 2013 | 06:21 PM
noeld's Avatar
noeld
in my 89 fxr primary
Old Mar 17, 2013 | 07:29 PM
Dan89FLSTC's Avatar
Dan89FLSTC
OEM clutch, any type ATF will work fine.
Bigdave12768
Mar 20, 2012 09:19 PM
RENORRIS
Apr 27, 2011 07:55 PM
Rockrspud
37
Aug 1, 2010 06:51 AM
Black Bart
25
Jul 24, 2007 08:19 AM
DaveT
Nov 28, 2006 02:26 AM
