Oil Archive (no new posts) An archive of oil related questions and comments.
Help!!! What did I drain?
Old Aug 28, 2013 | 08:14 PM
BrianRx74's Avatar
BrianRx74
Default Help!!! What did I drain?
So I'm changing my own fluids for the first time on my new Harley and I think I loosened the wrong plug. I now realize the correct locations of the 3 drain plugs. Not much came out, so I knew something was wrong. The plug is on the right side towards the front under the cam cover. It took a 1/4 inch hex socket and was tough to get out. It did not have an o-ring on it, which also told me something was wrong. What came out of that hole? Any help would be appreciated.
Old Aug 28, 2013 | 08:17 PM
Uncle Chester's Avatar
Uncle Chester
That's a pipe plug in your crank case. When you put it back in make sure it is tourqed correctly as the tapered plug can do some damage if over tourqed.
Old Aug 28, 2013 | 08:48 PM
Buckinfitch's Avatar
Buckinfitch
engine oil drain. It's under the frame in front of the rear wheel on the exhaust side.
The trans drain is between the shocks under the trans.
Primary is at the bottom of the primary cover.
Old Aug 28, 2013 | 10:13 PM
doc ock's Avatar
doc ock
You could watch a few videos on youtube to do the job right.
Old Aug 28, 2013 | 11:02 PM
BrianRx74's Avatar
BrianRx74
Thanks for the help. I'll look through my service manual to find the right torque. Do I need to worry about replacing the fluid that came out?
Old Aug 29, 2013 | 01:00 AM
Uncle Chester
You should not have gotten much fluid out of there, I wouldn't worry about it. Just check your oil level when your done to see if your low.
Old Aug 29, 2013 | 01:14 AM
ynots's Avatar
ynots
The only way you can replace that fluid is to split your crank case, lay the primary side case on its side and use a 1/4" hose to purge marvel mystery oil into the oil gallery until it comes out the pee pipe. Reassemble and everything should be fine. Chapter 34-1 in the service manual
Old Aug 29, 2013 | 02:44 AM
Ron750's Avatar
Ron750
This pic is how my 88 looks. Mag plug is the drain plug.
Old Aug 29, 2013 | 03:10 AM
Jackie Paper's Avatar
Jackie Paper
That is the incorrect picture for his Softail Fatboy. He pulled the plug used to check for oil pump failure and sumping. Apx 20oz of oil cam out. The amount left in the cas that the crank always runs in. Of course it is always being added to and removed when it runs. Need to use the proper sealer and of course proper torque to reseal it. Since it's a tapered pipe thread, it can actually split the crankcase and break off a piece the size of your hand. Someone on here did it in the last year. His drain for engine is in the frame cross member. Transmission is up between shocks and primary is on the lower rear of primary cover. When you start it up, you will loose that much and need to add more to the oil bag. Then check your level when hot and fill slight above middle of stick or if's it's really hot to top line if desired.
Old Aug 29, 2013 | 03:13 AM
Ron750's Avatar
Ron750
Originally Posted by RIPSAW
That is the incorrect picture for his fat boy. He pulled the plug used to check for oil pump failure and sumping. Need to use the proper sealer and of course proper torque to reseal it. Since it's a tapered pipe thread, it can actually split the crankcase and break off a piece the size of your hand. Someone on here did it in the last year. His drain for engine is in the frame cross member. Transmission is up between shocks and primary is on the lower rear of primary cover.
On my smart phone, I couldn't tell what kind of bike he had. Is my picture correct for any 88 or only touring?
