Oil Archive (no new posts) An archive of oil related questions and comments.
Primary Chaincase service level.
Old Sep 4, 2014 | 04:14 PM
hawkpilot777's Avatar
hawkpilot777
3rd Gear
Default Primary Chaincase service level.
HD 2005 roadking, just put lube in the primary... Bike is set Level. What is the best visual reference to verify proper service level? (is it full/correct?)
Book says: "lubricant must not be higher than the spring."
What is the "spring"?
(Is it the circular disk w 6 bolt heads?)
I put about ~32-34 oz in already (Mobil1 20w50), and can barely see the fluid below the "disk"... I just don't want to over-service the primary... Am I looking at the correct "spring"?
I spilled a little from the first qt, so I lost track of exactly how much - swatted at a mosquito (Wisconsin) :-)
Old Sep 5, 2014 | 04:49 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Here`s the level, it is the same for all wet clutch big twins.
Old Sep 5, 2014 | 04:58 AM
Campy Roadie's Avatar
Campy Roadie
The clutch diaphragm spring. It's on the end of the clutch basket.
Old Sep 5, 2014 | 04:36 PM
hawkpilot777
3rd Gear
Default Trouble opening the page.
I clicked on the attachment that you provided, but it will not open. Is there another path (website or place) where I can go to view it? Thank you for your effort, but I just can't see it yet. Please help.
Old Sep 5, 2014 | 05:04 PM
qtrracer's Avatar
qtrracer
Post more. LOL. I think you gotta have 5 posts or be a member for at least 5 days to view or post pictures.
Old Sep 6, 2014 | 05:58 PM
hawkpilot777
3rd Gear
Default Ha! Ok.
I finding know that was a rule. That was my first and only post. And I specifically signed up for that question. Thank you again!
Old Sep 9, 2014 | 08:59 AM
FenderGuy53's Avatar
FenderGuy53
Just pour in 38 ounces and be done with it...
Old Sep 9, 2014 | 02:15 PM
qtrracer's Avatar
qtrracer
On a listed 32oz wet fill spec? ok....................
Old Sep 9, 2014 | 02:34 PM
FenderGuy53
Good catch, gttracer. Just noticed that the OP has a 2005 RK, so the spec must have changed on the newer models.
To the OP, use whatever your owner manual says. Mine says 38 ounces.
Old Sep 9, 2014 | 03:26 PM
jpowell490's Avatar
jpowell490
I always just put a quart in mine and bolt it up. A full quart is plenty.
89FLHTC
EVO
14
May 2, 2016 04:44 PM
donnybaaker
Apr 1, 2013 09:37 AM
big TYME
May 10, 2012 10:20 PM
OneBlackFly
Apr 22, 2012 08:29 AM
JONNIEROCK
Dec 7, 2010 01:19 PM
