Pan America Pan America Forum Only
Hard start
Old Feb 7, 2022 | 09:06 AM
RevenantDescent's Avatar
RevenantDescent
Default Hard start
Well it finally happened. From the usual hard starts here and there, morphing into consecutive hard starts until finally now just tonight? My bike hard started into oblivion. The starter isn't even trying to spin anything now.
I'm going to put it on the charger until the battery is full, maybe it just needs juice?
Or maybe after all of this time the starter was slowly self-destructing The way my fuel pump was.
I'll keep you posted
Old Feb 7, 2022 | 11:11 AM
depthsounder's Avatar
depthsounder
That sucks, I had to replace my battery to resolve a similar issue. The original battery voltage would drop so low when starting that it would shut off the ECM.
Old Feb 7, 2022 | 11:36 AM
07UltraGuy's Avatar
07UltraGuy
similar issue w/ my '07 a while ago.
Battery seemed plenty strong. 12+ VDC when measured, meter at above 14 when running.
Started to give slow, difficult starts. very intermittently.
Bike sat for about a week w/o the tender connected, and it wouldn't start at all.
Connected my charger and let it charge.
Measured above 12VDC again, so I tried to start it and it was real weak.
Watched the meter while trying to start it and I saw the voltage drop to like 5 volts.
Let the charger sit on it and was able to start it, then rode directly to the shop for a new battery.
Hasn't happened again since.
Old Feb 7, 2022 | 11:45 AM
RevenantDescent
Yep, all my symptoms are pointing to this as well. Did the warranty cover your battery?
Old Feb 7, 2022 | 12:17 PM
RevenantDescent
Really wish a tech or HD in general would have connected the dots to a shitty battery for these starting issues I was having instead of telling me it was a model wide known issue with no 100% fix yet
Unless I'm being too hopeful and I'll have whining starts again even with a new battery
Solodolo
Jun 4, 2021 03:44 PM
Damien Bessent
Nov 8, 2014 07:26 PM
Locmoss
Sep 4, 2013 08:56 PM
scot210
Jun 25, 2012 01:03 PM
Fastfwd
Apr 19, 2012 08:51 AM
