Pan America Pan America Forum Only
TPMS alert
Old Aug 12, 2022 | 05:50 PM
mountaintime's Avatar
mountaintime
Question TPMS alert
Is the TPMS alert adjustable? I run pressure lower than what the bike likes. So the icon is always lit up.
Old Aug 21, 2022 | 08:48 PM
doxbike's Avatar
doxbike
probably, as the top end speed is changed with knobbies installed by the dealer
Old Aug 22, 2022 | 03:16 PM
bofh1599's Avatar
bofh1599
Similar issue. When I start, I open the bike display and return to main screen, and switch between this display and the main screen occasionally with the HOME button to check tire pressure. I run with 200 and 250 kPa pressure.
Old Aug 23, 2022 | 09:27 AM
Toe Shifter's Avatar
Toe Shifter
Why not just run the custom home screen where all the information is on 1 screen? I run the home screen in white (hold the home button for 5 seconds) and then I have ambient temp, engine temp and oil info in upper right corner. I have all TPMS info in upper left corner. The lower left corner gives me Fuel Range and both trip meters. and the lower right is turn by turn directions if I have a gps route set on my phone.
Old Aug 26, 2022 | 08:39 PM
freeriders's Avatar
freeriders
The dealer can lower it with a computer setting associated with knobbies whether or not they are actually on the bike, but the ecm will also limit your speed to just over 100 mph (103 I believe). I just accept the warning and keep my tpm in the widget display.
Old Sep 15, 2022 | 11:47 AM
a99miata's Avatar
a99miata
I wonder how much the sensors cost and what the life of the sensor battery is?
Mapman37
Harley-Davidson Street
Jun 2, 2021 08:46 AM
Mark Edw
Aug 25, 2017 11:16 AM
2015 Harley Davidson Street Bob Guy
Nov 16, 2015 08:35 AM
Javawave
Oct 24, 2008 03:54 AM
