Panhead head question....
Old Nov 23, 2017 | 11:32 PM
OzBobPanGlide's Avatar
OzBobPanGlide
If you look hard, both pipes appear to have dual mounting bolts.
STD heads had triple mounting bolts, Yes?
Custom for sure, maybe cut the flanges from first set of pipes and re-weld to preferred set.
Old Nov 24, 2017 | 06:45 AM
johnjzjz's Avatar
johnjzjz
to me the rear head shows welding of a shovel spicket on a pan head
twist caught the off angle calling them custom made
you will have to mod what ever pipes you get to fit by removing the head pipes attachment and re installing at the correct clocking
Old Nov 24, 2017 | 06:47 AM
johnjzjz's Avatar
johnjzjz
sorry Bob I did not see your second post about the pipes
Old Nov 24, 2017 | 03:53 PM
CanadianRocky's Avatar
CanadianRocky
V-Twin has a set of True Duals for a '52 PanHead.... so that will take care of the fit to the frame.... and after talking to my OldIronGuru in town, I am pretty sure that the fix is as you suggest.
Cut the Flanges, bolt in the exhaust, check the fit....then cut the Panhead ends off, and weld up the pieces to fit. I want to put on a set of flex covers, so if it is done right, I might not need to recrome the pipes right away.
I have a good buddy who is a fitter so it should go ok.
Old Nov 24, 2017 | 05:39 PM
TwiZted Biker's Avatar
TwiZted Biker
Love a good plan, pics when you done please.
Old Nov 24, 2017 | 05:42 PM
CanadianRocky
I will order up the parts and then probably do the job in early April. I will take picts all the way through the process. Also the other changes I will be making.
Old Nov 24, 2017 | 06:11 PM
TwiZted Biker
Before you buy drop one of the pipes and see what the end looks like, see if they left a lip or is it flushed off. May make a difference in what set you buy shovel or pan.
Old Nov 24, 2017 | 06:19 PM
CanadianRocky
The parts take about a week to get here (across the border and have to clear customs) so I will get the bike to my buddies and take all the bits off I want to replace and make sure I order the right stuff. I will repost pictures before I order.
It will be a fun project. I am selling my ‘017 Glide and riding the Pan to Sturgis from home. About 800 miles. Next winter I will take the frame back to stock.
Old Nov 24, 2017 | 09:16 PM
RFG7680's Avatar
RFG7680
Been a while since I sold my 48. You guys are on point about the exhaust. My question is the intake. If I recall the manifold where it meets the head is the same size as the port on the head and has a rubber seal under the clamp. Those heads have been molested pretty good. I'm curious as to what that looks like under there.
Old Nov 24, 2017 | 09:34 PM
CanadianRocky
We also noticed it was odd and will have a look when we start working on the Pan.
