juice brake line routing
Old Oct 19, 2022 | 04:16 PM
hellonewman's Avatar
hellonewman
What was on the bike before?
Old Oct 19, 2022 | 04:19 PM
hellonewman
My pedal on the 66 looks the same. I wonder if the master is wrong.
Old Oct 19, 2022 | 07:34 PM
omar1951's Avatar
omar1951
It had an OEM master cylinder that hadn't been used in so long that it was destroyed. I never looked at the hole in the piston. The plunger was rotted from brake fluid. I believe the pedal is '59 and later, as it looks like the one one my '68, and my wife's '65. Still wondering if I can find out the diameter of the plunger without disassembling anything else. Would also like to find out if the hole in the master cylinder piston is big (7/16") or small like the one in the pic.
Old Oct 20, 2022 | 02:24 AM
Speeding Big Twin's Avatar
Speeding Big Twin
I’m not sure which pedal you have but at least it sounds like you’re aware there was more than one type. But what about your mounting bracket? First bracket below was apparently for late-59–69.
Next example was for 58–early-59.
Eric
Old Oct 20, 2022 | 04:22 AM
omar1951's Avatar
omar1951
Eric
Interesting and informative reply. Just by eyeball, it appears that the difference between the 2 is the location of the pedal stud, which makes a difference. The 1st one would locate the pedal higher up, which would, to a certain extent, take the angle out of the plunger coming out of the master cylinder. From what I've read, the only difference in the pedal is the location of the "bend", or offset, so that the pedal would clear the cam chest cover. I don't know whether the clevis pin hole location is different between the 2. Unless I can find a bracket like the first one, I guess I'll end up turning the plunger down and opening up the hole in the piston that receives the plunger. Thanks for taking the time to show me the differences.
texashillcountry
EVO
32
Mar 25, 2016 04:39 PM
Sincecrazy
Apr 27, 2011 12:03 AM
Sincecrazy
Wheels/Tires
Feb 25, 2010 08:21 AM
jbweld
May 24, 2009 07:55 AM
gsgtrman
May 26, 2008 11:38 AM
