Transmission Gear Oil
Old May 26, 2023 | 01:51 PM
panz4ever's Avatar
panz4ever
Default Transmission Gear Oil
So while waiting for the repair on the transmission I started looking at gear oil. I know that there are a lot of different ideas regarding brands used. To date allI have ever used is HD straight 60. A buddy of mine has an S&S 93 with a Baker 6 and he uses BelRay 85w/140. He rides his Pan hard (doesn't beat it up tho). He swears by it in his tranny. Other brands that I have looked at/ started reading about...Red Line Heavy Shock Proof, Amsoil 75/110, Spector 70/145 & Lucas 85w/140. I really like the idea of the higher number for the "hot" range, and since I am using all Andrews gears in it I figured it would be worth the money to use a decent gear oil.
Any/all input/feedback welcome.
Old May 26, 2023 | 02:30 PM
johnjzjz's Avatar
johnjzjz
The factory book was written while gear oil was available
- but the factory book tells you to use motor oil in what ever straight weight you use in the engine in the trans -
reason it has brass in it - hi gear bushing - 1/ 2 under the gear as well as the 3 /4 under the gear - and in the lid shifting parts - early 3rd gear also had a bushing
gear oil eats the brass and causes 3 times the normal wear - but you buddy having a evo trans can use gear oil as nothing is brass in it
we use this 25 years and we do an easy75 4 speed and 3 with reverse thrown in as well gear boxes a year
Old May 26, 2023 | 03:02 PM
hellonewman's Avatar
hellonewman
Not all gear oil eats brass..
GL4 is okay GL5 is not but GL5 is more suitable to hypoid gear applications anyway
Old May 26, 2023 | 03:18 PM
470004's Avatar
470004
Question. Is it ok to use Synthetic 60W or just stick with Dino? Thanks
Old May 26, 2023 | 06:26 PM
johnjzjz's Avatar
johnjzjz
I never bought into amsoil but many have - racing taught me about zinc in oil is what you really need above all else
do not care what’s others use - my experience is what i have spent my money on and learned the hard what what and what does not work
the 60 we use is loaded with zinc and it does the job - when 100 customers have asked me what did you use in my bike i need to get t some of that
Old May 26, 2023 | 07:15 PM
hellonewman
I have found on old Car engines oil consumption increases dramatically with full synthetic oil, wouldn't surprise me if the same thing happened on an old clunker Harley too. I checked the oil in one of my cars mid season, the PO had put royal purple in it prior to me buying it. I was down 10 liters out of 18 I thought it leaked out! At the time I wasn't able to run out and get more of what was in it and I had conventional 20W50 on hand. Some oil is better than no oil so in it went. I drove that car the rest of the season with no noticeable consumption and then changed the oil the following spring to a conventional oil and haven't had an issue.
Old May 26, 2023 | 07:52 PM
johnjzjz's Avatar
johnjzjz
Old May 27, 2023 | 06:58 AM
Baird's Avatar
Baird
someone ran it dry but added Slick 50 so everything is OK.
Just throw in 4 quarts in and get out there.
SWThomas
Jul 4, 2021 01:30 PM
Rynb15
Oil Archive (no new posts)
Feb 25, 2012 07:31 AM
Woodchuck
Jun 18, 2011 12:37 AM
mjaw
Feb 8, 2008 11:18 AM
HDJoe
Jun 2, 2007 05:21 PM
