reverse
Old Oct 13, 2023 | 07:01 PM
Max Headflow's Avatar
Max Headflow
Originally Posted by johnjzjz
That’s an interesting question - idea
i do not believe the travel timing crosses from a tank shift lever location to a ratchet stop location
the hand shift gate has stops to help and they are not exact to one another — as the ratchet is consistent in travel distance < the drum timing to the ratchet stop is the deal for no over shifting — un like the hand shift as you can pass the stop and hit a neutral between 2 gears - it only goes to the location you put it unlike the ratchet is spring loaded
The travel timing on a tank shift is set by the shift gate on the tank. The timing for a foot shift is set by the travel in the ratchet top.. Both have detents in the drum to hold the tranny in gear.. Obviously you can't connect a foot shift lever to tank shift top and expect it to work all that well..
shovelchop
Panhead
Apr 16, 2023 06:19 PM
Harleymarlboroman
Panhead
Oct 1, 2022 07:24 PM
BelchFire
Jan 18, 2022 05:32 PM
old mago
Panhead
Aug 13, 2018 02:07 AM
james b.
Mar 16, 2011 04:52 PM
