65 pan ignition advance
Old Oct 23, 2024 | 09:32 PM
Max Headflow's Avatar
Max Headflow
Default 65 pan ignition advance
I've been working on the 65 pan and have had it running. It's a fresh rebuild of pretty much everything for those not following the build here..
https://www.hdforums.com/forum/panhe...-the-65-a.html
I figure to post this separate so other don't have to wade through the crap.
Anyway, in process of setting the timing I followed the manual for setting the timing. When I do so, the static timing (0 rpm) is like 5 degrees after TDC. I'm not sure this is kosher.. Seems to be part of the reason why the bike can be a little finicky starting cold. I know that when you set the timing statically full advance by twisting the points cam the timing will be a little retarded but I'd expect not to be that far off.. Am I wrong?
What should the timing curve be? Say 5 adv deg while cranking?
Anyone know what the specs are for timing advance? The manual says full advance at 1500 to 2000. Idle speed. 750? So go from 5 deg to 35 in 750 to 1250 rpm? All previous were start the bike, and advance the timing..
Old Oct 24, 2024 | 08:09 AM
wfolarry's Avatar
wfolarry
You should set it 5* advanced
Old Oct 28, 2024 | 04:52 PM
johnjzjz's Avatar
johnjzjz
We do it this way with the line in the center of the hole front piston is at max advance - test light on the points and rotate the distributor cam lobe full rotate the distributor to it lights on the point arm or coil but coil is a thing to watch
CipherViper
Jul 22, 2023 12:10 PM
98hotrodfatboy
Aug 22, 2018 01:48 PM
traildog
EVO
33
May 18, 2014 10:22 PM
HDF Tech
Aug 5, 2012 04:19 PM
FX4 Level II
May 20, 2008 03:22 PM
