Oil pump
Old Aug 21, 2008 | 12:15 PM
FilthyLucre's Avatar
FilthyLucre
Originally Posted by d_slat
panheadmcc, another thing you might want to try is tightening the bolts down in multiple steps. When I did mine, i first just snugged them slightly, then tightened them to 10 ft. lbs, then to 25, and then to 45. This might help from squishing the gasket where you tighten the first bolt and keep the clearance to a max.
I'm sure that's a typo, it should be inch pounds not foot pounds.
Old Aug 21, 2008 | 08:12 PM
PANHEADMCC's Avatar
PANHEADMCC
6th Gear
I was told by a mechanic that the gears should be .003 shy of pump body so I had the gears surface ground to fit. If in fact they are suppose to protude I hope it will pump oil! I am putting motor in frame this weekend. Guess I will find out then.
Old Aug 22, 2008 | 06:15 AM
PANHEADMCC's Avatar
PANHEADMCC
6th Gear
Default Oil pump
I was told gears should not protrude past body so I had gears surface ground to fit. I hope it will still pump oil. putting motor in this weekend. will find out then I guess.
Old Aug 22, 2008 | 11:59 AM
d_slat's Avatar
d_slat
yup, sorry about that - should have read it again before i posted it!!
Hairy Larry
Milwaukee Eight (M8)
35
Apr 5, 2019 09:42 PM
Tom G.
Engine Mechanical Topics
May 4, 2018 04:47 PM
charlesrt88
Shovelhead
Oct 26, 2015 08:27 AM
imboden
Shovelhead
Oct 7, 2013 05:04 PM
PANHEADMCC
Oil Archive (no new posts)
Jan 1, 2012 02:43 PM
