Pan Head generator ???????
Old Sep 2, 2008 | 07:23 PM
tadams's Avatar
tadams
Default Pan Head generator ???????
I have finally ridden my bike today after a week fo kicking. The only thing I done different... I put gas in, I charged the batt, and put four new plugs in.
While it was running today I put a tester on the batt post and reved the eng and nothing changed on the readings. If the gen was good and the reg bad could such a thing happen.
Old Sep 2, 2008 | 09:50 PM
pococj's Avatar
pococj
Yep. How do you know the gennie is good?
Old Sep 3, 2008 | 06:54 PM
duffy1's Avatar
duffy1
Default gennie
Do not take me wrong but did you polarize your generator ?
Old Sep 4, 2008 | 09:17 AM
tadams's Avatar
tadams
I have to shamefully admit that I did not until after I put it on and rode the bike. As I was enjoying getting the bike going, that is when I read the instructions.
Old Sep 4, 2008 | 09:56 AM
duffy1's Avatar
duffy1
Default gennie
so now is it charging now ? and you should here it as well it should whine
Old Sep 4, 2008 | 05:10 PM
tadams's Avatar
tadams
no noises of any kind. I am going to buy a new one. That will eliminate any questions.
Old Sep 4, 2008 | 06:52 PM
Pequerhead's Avatar
Pequerhead
1st Gear
Default No generator
Put lead of voltmeter on gen terminal of voltage regulator and other on good ground. See if any voltage is being generated. Should be around 6.8v to 7.2 volt. Voltage regulators go much quicker than a generator and are much less costly. Get yourself a Clymer manual for your bike. Tells how and shows with diagrams correct way to check v. reg. and generator. If your regulator is shot you wont charge the battery. By not polarizing the generator, you may have burnt contacts in regulator. do it the smart way and work your way down the list. Dont replace unless you know for sure part is bad.
Old Sep 5, 2008 | 05:34 AM
SloRoll's Avatar
SloRoll
6th Gear
If it's a 12 volt conversion, like mine, you should see 13 - 14 volts when the bike is running. If you only see 11 - 12, the generator is not charging the battery. A new Cycle Electric gen costs around $300.
Old Sep 13, 2008 | 08:58 AM
charliea's Avatar
charliea
solid state regulators are more reliable than the old style. I keep extra plugs under my old regulator cover. Not original but they work well
H3llbilly
Apr 13, 2015 04:56 PM
mr_reality
Jul 28, 2013 08:58 AM
WAFATBOB27
May 23, 2011 01:29 AM
robertj74
Jul 25, 2009 06:44 AM
HeatherC
Aug 22, 2007 06:54 PM
