panhead gen help!!
Old Mar 22, 2010 | 04:40 PM
poleclimber67's Avatar
poleclimber67
Stage I
Default panhead gen help!!
Ok guys, got a 49 pan ol school chop last fall. After about 500 miles the ignition switch burnt up. I replaced and wired in a new switch as well as new wires to the voltage reg. My bike is ussing a VW type voltage reg. After hooking it up, polorizing the gen and firing it up, i have issues! At just above idle, the lights will brighten a bit, but if you rev it, the voltage seems to go crazy and the headlight will start blinking and such. If i put a vlot meter on the battery, it will go crazy and move from anywhere from 6 v-16v, just crazy, jumping all over the place. So, i thought this must be the reg, so i bought another rer and placed a new battery in it, and the same thing happened??? I have the B+ hooked to the battery, the dF hooked to F of the gen, and D+ goes to A on the gen. Thats how it was originally hooked up and it seemed fine for awhile. I wouldnt think the gen is bad as it seems to charge at just above idle.
Please any help would be appriciated, also to polorize, jumping from the battery to what side of the gen should i jump it too? (making sure im right) Thanks a bunch!!
Old Mar 22, 2010 | 06:21 PM
sqdealgeorge's Avatar
sqdealgeorge
Is this charging system 6 volts ? must be because alot of guys were using the VW gens back then I would convert to 12 volts and use an aftermarket 12 volt gen plus a Delco-Remy or Accel volt reg If this has a stock gen have someone check it and go to the Delco or Accel system If you need part numbers let us know
Old Mar 22, 2010 | 06:27 PM
Captain Itch's Avatar
Captain Itch
Sponsor
I can only tell you about 6 volt 3 brush system ..The 3rd brush being able to move back and forth to vary the voltage but still uses a regulator
__________________
www.Captain-Itch.com
Old Mar 22, 2010 | 09:33 PM
Neil74's Avatar
Neil74
Did you polarize your generator after installing new battery? Momentarily touch a wire across Gen. Terminal( armature post) and the Battery terminal you should get a small spark. Restart bike an check output again. Polarize with bike not running.
Old Mar 23, 2010 | 10:24 AM
panz4ever's Avatar
panz4ever
Couple of thoughts on this...
"Charging rate goes crazy" (fully charged battery + high charging rate)... means regulator is failing to reduce output as it should. Problem is in either faulty regulator or generator.
To determine if regulator is at fault - disconnect F terminal lead at regulator to open generator field circuit. If charge rate drops to zero, trouble has been isolated to regulator. If charging rate continues, generator field circuit is grounded internally or in wiring harness.
So questions for you. What caused the switch to burn out in the first place? Any chance that it also affected your generator? Are you sure you have the switch wired correctly?
To do the test on the bike are you connecting the ammeter between the battery positive terminal and regulator terminal marked "BAT"
bremsstrahlung
Jul 27, 2017 01:41 PM
tnguyen7607@email.vccs.edu
Jan 25, 2017 12:21 PM
adamk
Electrical/Lighting/Alarm
11
Mar 31, 2015 04:22 AM
highenergy
Jan 3, 2015 09:45 PM
bikercouple
Mar 25, 2014 06:18 PM
