Valve Problem?
Old Apr 19, 2010 | 08:55 AM
48FLpan's Avatar
48FLpan
Default Valve Problem?
48 panhead solid lifters. Had noisy valves. Adjusted valves, found rear intake had 1/8 inch play. Got them right, second and third check. Rode to work and back (30 mi) next day. Ran great, not noisy at all. Rode to work again. On way home after work noticed rear cylinder gotten noisy again. Next day cheacked and rear intake 1/8 play again. Distinct "clinck" sound when motor rotated to rear intake fully raised position. I know its not good - broke or bent rocker or dropped valve? I know its hard to diagnose with hearing it. Any ideas?
Old Apr 19, 2010 | 01:02 PM
48pan's Avatar
48pan
Just a thought have you checked your pushrods for straightness. Put the pushrod on a piece of glass and roll it. Should tell you if there is a bend to it. If you had a stuck or bent valve you'd have some backfiring going on. You can take the pushrods out and blow some air in the cyl and see if it leaks out anywhere. Do you get the noise with the pushrods adjusted correctly? 1/8 in. clearance is quite a bit, could explain the noise when the valves seat. Haven't had much experience with bent or broken rocker arms but I would think that would be a continuous and would open/close exhaust too soon or late causing timing problems. Just a thought. Good luck and keep us posted.
Old Apr 19, 2010 | 03:29 PM
48FLpan's Avatar
48FLpan
Nice bike 48pan. Mine is not restored to original, has some updates. Thanks for the reply.
Guy that listened to it to is pretty sure that the noise is the valve-spring. Thinks the rocker is slipping off pushrod when raised. Will know for sure in a day or two.
I know I should have checked pushrods, but didn't have any around and wanted to ride. Never enough time.
Old Apr 21, 2010 | 08:53 AM
sqdealgeorge's Avatar
sqdealgeorge
Check the roller on the lifter assembly (roller rides on the cam ) Maybe the roller bearings are failing ? or have failed
Old Apr 21, 2010 | 03:57 PM
Kuda's Avatar
Kuda
Definately check the lifter. If the rod's not bent then the lifter's probably going south. Don't wait 'till it grenades and pukes metal through your motor, pull it and check it...
-Kuda
'49 panchop
Old Apr 22, 2010 | 11:17 AM
greenbikemike's Avatar
greenbikemike
3rd Gear
+ 1 on the roller
Old Apr 30, 2010 | 04:54 PM
48FLpan's Avatar
48FLpan
Default You're Right!
The needle bearings came out of the roller on the rear intake lifter. Luckily they did not get jammed in any of the gears under the cam cover. New lifters and I am good to go.
Old Apr 30, 2010 | 04:57 PM
sqdealgeorge
Rock on !
memphisharley
Engine Mechanical Topics
18
Sep 8, 2018 06:39 PM
vittt000
EVO
Aug 12, 2012 02:21 PM
kiowadriver
Shovelhead
Jun 27, 2012 04:00 PM
dan61t
Apr 24, 2012 07:24 PM
scooty
Exhaust System Topics
15
Jun 23, 2008 08:30 PM
