64 panhead insight
Old Aug 29, 2006 | 09:07 PM
picasso's Avatar
picasso
Stage I
Default 64 panhead insight
i am having problums adjusting transmission back to tighten primary belt.tried to tighten back wheel having the chain pull it back but of course it only pulled one side making the primary belt shift. what is the proper way to adjust trans evenly.thanks picasso[8D]
Old Aug 31, 2006 | 07:33 PM
pittguy's Avatar
pittguy
Default RE: 64 panhead insight
Dont run the belt too tight,esp if primary is enclosed.Completely loosen final chain drive,loosen all tranny attach hardware,dont forget the one by itself below kicker cover.The single bolt jam nuts need loosened on tranny adjuster.Loosen adjuster,this may or may not move tranny back.If not loose enough to physically move tranny aft by hand or light prying.Remember that tranny may **** somewhat and throw primary and final drive alignment off.Check with straight edge once desired primary tightness is reached,Snug tranny down and recheck.Once your happy tighten tranny down,tighten adjuster jam nut if there.Now tighten and align rear chain.Sometime this takes awhile and an extra set of hands may help.
Old Sep 1, 2006 | 08:49 PM
pittguy's Avatar
pittguy
Disconnect linkage to trans also and adjust after desired tension on belt.
Jethro
EVO
Apr 27, 2012 08:56 PM
kswan
Shovelhead
Mar 23, 2012 11:37 AM
BMdeckie
Apr 27, 2009 10:11 PM
99octane
Feb 13, 2008 12:50 PM
silburnnyc
Jan 19, 2008 09:14 PM
