Pinkerton main jet
Old Jan 16, 2014 | 11:52 AM
FL54's Avatar
FL54
Default Pinkerton main jet
I just replaced the float and needle and seat in my type M Linkert. This may be a dumb question but is the main jet supposed to protrude up into the Venturi or does it remain in the well below the level of the Venturi?
Thanks in advance.
Old Jan 16, 2014 | 12:01 PM
FilthyLucre's Avatar
FilthyLucre
From the drawing in the knucklehead manual the nozzle comes almost half way through the ventrui
Old Jan 16, 2014 | 05:07 PM
johnjzjz's Avatar
johnjzjz
plus one on the jet 1/2 way into carb opening than the spring, the bowl than the washer for the bowl and the bowl nut holds it all up in place = the direction of the main has no set it this way as long as its all the way in --
If the venturi is not tight in place, if not it will give you an issue tuning sometimes // they are very forgiving But to a point -- jz
Old Jan 16, 2014 | 10:43 PM
FL54's Avatar
FL54
That's what I thought. Thanks for your help.
Zenmoto
Carburetor Related
Feb 11, 2017 08:18 AM
FL54
Panhead
Jan 16, 2014 12:09 PM
Bill C
Carburetor Related
May 31, 2011 10:09 PM
kgb44
Exhaust System Topics
Apr 17, 2009 01:15 PM
bubbas1
Jan 4, 2007 02:18 PM
