Timer advance
Old Feb 10, 2014 | 10:27 AM
FL54's Avatar
FL54
Default Timer advance
I've been following the thread from JayDee and it got me to thinking (which can be a dangerous thing)
My '48 Pan (which I've had for over 35 years) never had the timer advance connected.
The PO had installed a solid piece of steel in the left handlebar to lock the left grip.
The timer is always in the fully advanced position.
My question is: is it worth restoring the spark advance cable? I think the only parts I would need are the outer cable (I have a spare inner wire), plunger kit, and any bracket that would be required to hold the cable in place.
Part of me wants to restore it to the original but the bike has always started and ran well so I also think "if it's not broke, don't fix it."
I'm interested in the feed back from the brain trust.
Old Feb 10, 2014 | 11:06 AM
old skool pan man's Avatar
old skool pan man
My 64 FL duoglide is 100% stock (except for the seat-recovered) and while I get a kick out of retarding the timing every once in while to get the infamous Harley lope, which really isn't good for the lower end....if it's working for you now on startups and such fully advanced...leave well enough alone. Nothing like a easy to start Pan..
Old Feb 10, 2014 | 11:52 AM
johnjzjz's Avatar
johnjzjz
as a kid riding pans as choppers we never had the dist move, if it has not hurt it than your doing good leave it alone, it likes it why make it something else -- johnjzjz
Old Feb 11, 2014 | 08:22 AM
FL54's Avatar
FL54
Thanks for the responses and I'll take your advice and leave well enough alone. Besides, it 's always easier to do nothing.
Old Feb 11, 2014 | 01:55 PM
johnjzjz's Avatar
johnjzjz
Very nice bike BTW
Old Feb 16, 2014 | 06:17 PM
old skool pan man
Thank you!!!
Old Feb 16, 2014 | 07:15 PM
johnjzjz's Avatar
johnjzjz
Thank you!!!
this is the style i build in the shop - we also do national AMCA champions
Old Feb 22, 2014 | 09:41 PM
OLD 96's Avatar
OLD 96
If you want to restore it to original condition I say do it. Is the cable still connected to the circuit breaker? If you want to leave it as is. You can disconnect the cable from breaker and use a spring to hold it in full advance position. Then pull circuit breaker to retard by hand for start. That is how it was done in the old days.
Old Feb 22, 2014 | 09:47 PM
johnjzjz's Avatar
johnjzjz
we had a dobie named Sadie 14 years - father was satin and mother was lady so we called her sadie - sweet pup
Old Feb 23, 2014 | 07:37 AM
FL54's Avatar
FL54
No, there is no cable and that would be the only somewhat difficult task to thread the cable through the bars. I've heard of adding a spring as you suggested. Thanks for your input Old96, but I think I'll leave well enough alone. It's worked well for many years.
