BitsaPan Update
Old May 22, 2014 | 02:55 PM
Killerman#1's Avatar
Killerman#1
Cool Mag time
Installing a mag and timing it on an old harley is defiantly a learning experience, if you get a used one be sure it's still tight, ie "worn shaft bushings". Mag's are very touchy in the point gap department so any looseness will just make it harder to set up. Also, clearance between the mag body and front cylinder cooling fins can be a problem. Be prepared to die grind fins for clearance. I've found some of the older jugs clear with little problem, newer castings clearance work is needed. Like I said mags can be a pain in the *** if you're just going for the look. Ride that scooter bro. Killer
fortyeight630
Feb 18, 2012 09:24 PM
SMF
Oct 24, 2010 09:56 AM
spider-harley
Nov 30, 2008 12:13 AM
