Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
powder coating question..bondo
Old Nov 20, 2011 | 09:34 PM
Wpittman's Avatar
Wpittman
Default powder coating question..bondo
crazy question but i just got an old chopper frame i want to powder coat. It has bondo filling out some of the welds.. can it be powder coated over???
Old Nov 21, 2011 | 06:48 AM
omgtkk's Avatar
omgtkk
Standard Bondo...No. You can't powder over it. I believe there is a specific body filler that will work under powder. Hopefully one of the experts will chime in with it's name.
Old Nov 21, 2011 | 06:50 AM
CtCruzer's Avatar
CtCruzer
Ive done couple of car frames
filled with jb weld per powder coater so far so good
Old Nov 21, 2011 | 03:21 PM
JRK5892's Avatar
JRK5892
JB weld does OK if you are only doing a one shot powder... 2 shot, no way it will outgass even though primer. metal lab is a powder safe metal filler and that sucks too... really the only good way to do it is to brze or high temp solder in the fill areas... that is the cleanest and best way to fill for powder
Old Nov 22, 2011 | 08:17 PM
TIGguy's Avatar
TIGguy
Default Lab Metal
The only filler I have found to use when parts are to be powder coated is Lab Metal (hi temp). It's not a two part filler like Bondo and takes a while to dry. It actually contains metal powder which is why it can be powder coated.
You will need to grind out the old filler and redo with Lab Metal which is available at any Fastenal dealer. SUPER EXPENSIVE but it works.
Old Nov 23, 2011 | 10:47 AM
JRK5892's Avatar
JRK5892
metal lab just does not last man, if you do anything that requires more than 1 coat and tins will 90% of the time req a clear... it cracks and outgasses after full cure. we have a huge jug of it that just sits in the corner hahaha
Old Nov 28, 2011 | 07:39 PM
Wpittman's Avatar
Wpittman
ok so thats a no to the jb weld, no to the metal lab and bondo. Next question what about lead as a filler...or maybe brazing and grind and polish.. or just add welds and grind and polish to cosmetically acceptable way say you the experts?
Old Dec 1, 2011 | 12:02 PM
JRK5892's Avatar
JRK5892
lead works great!!! we typically braze the area in... solder thends to deform
harleytuner
Powdercoat & Paint
Oct 17, 2012 11:52 AM
Dyflam
Powdercoat & Paint
Apr 29, 2011 11:15 PM
NYBill
Apr 2, 2010 01:05 AM
Lt Jake
Northeast Tri-State Area
Feb 15, 2010 05:47 PM
Derf121
Northeast
Mar 12, 2008 12:03 PM
