Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Which primer do I use?
Old Feb 23, 2012 | 06:42 PM
grizzwold's Avatar
grizzwold
Default Which primer do I use?
Hey guys, I'm planning on doing a rattle can job on my tank and fenders within the next week and I can't figure out which primer is right for the job. Everything has been bead blasted down to bare metal and I know I'm gonna have to do some body work first. I'm planning on using a satin black for a top coat but can't figure out which primer to use. So far I've seen sandable, self-etching, filler primer and just plain old primer. I've mainly been looking at the Rustoleum products but would be open to anything in a spray can that's relatively inexpensive (doing this on a tight budget). Any suggestions??
Old Feb 24, 2012 | 09:49 AM
JRK5892's Avatar
JRK5892
if you bead blasted that is a rough finish, your going to want to use a self etching primer, then a filler primer over that... i like dupi color out of a can but they all about the same, i would sugest that whatever you use, stick to that brand... they do not play well with others when it comes to rattle can... after your filler primer block it out before base coat
gnstalodz
May 19, 2016 04:58 PM
Tau511
Apr 16, 2014 05:28 PM
Double00Aught
Dec 1, 2008 10:24 PM
2007fxdc
Detailing
18
Sep 21, 2008 04:50 PM
Unibomber
Apr 20, 2006 04:08 PM
