Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Painting Jugs And Heads
Old Jan 6, 2013 | 07:19 AM
traildog's Avatar
traildog
Default Painting Jugs And Heads
I'm going to repaint the jugs and heads when they come back from the machine shop.
For those of you who have done this, did you try heating them up in a barbeque or smoker after you shot them?
I have a real nice, temperature controlled smoker I can use.
Old Jan 8, 2013 | 07:59 AM
traildog's Avatar
traildog
So, nobody has painted their engine?
Old Jan 8, 2013 | 09:44 AM
Scudda's Avatar
Scudda
I have never done it but from everything I have read most people Powder coat them. If I ever take mine apart That's what I'm going to do
Old Jan 8, 2013 | 09:48 AM
traildog's Avatar
traildog
Would that match the rest of the engine?
jimsflh's Avatar
jimsflh
On my old bike I used wrinkle black BBQ paint to touch up the motor, didn't heat it, just cleaned real well with laquer thinner amd painted, worked well. I imagine you could use hi temp engine block paint as well. I think the trick is cleaning well
Old Jan 8, 2013 | 10:49 AM
JRK5892's Avatar
JRK5892
i have painted and powder coated several motors... paint will chip and require touch up... never painted a HD motor but i have done a ton of metrics... it is all in the prep work to be honest that has to be clean! then we will bake the painted motor at like 150 for 30 min or so before install... here are some motors i have painted
thing is with paint you have to constantly touch it up... if you ever spill gas on it, plan on pulling the motor to repaint... powder you do not have to worry about that... here are just a few samples of both we have done... we actually have a forum members jugs, heads, and cases in the shop now all going black cherry then we are shipping them to Co, to have the jugs and heads diamand cut.. gonna be sick!!
and powder coated
Old Jan 8, 2013 | 11:23 AM
traildog's Avatar
traildog
Nice! Is $300 for the jugs and heads a good price quote for powder?
Old Jan 11, 2013 | 12:46 PM
DanDman's Avatar
DanDman
I just got done with mine. Masking took awhile. I used VHT Engine Primer & VHT Motorsport Case Paint satin black. The paint is supposed to be chemical resistant. I used a heat gun to help with the curing. I'll see how they hold up once installed.
Attached Thumbnails Painting Jugs And Heads-100_0949.jpg   Painting Jugs And Heads-100_0951.jpg
Old Jan 11, 2013 | 01:09 PM
harleytuner's Avatar
harleytuner
Did Diamond heads move? Last I new they were in Henderson Nevada. We have to set there now. Or is there another company that is doing it?
Old Jan 11, 2013 | 01:49 PM
JRK5892's Avatar
JRK5892
Nope it is Diamond-heads... if you have a set there you know they did not move bud... just an accident when i typed it in... not sure off hand while i thought it was in Co and not NV hahaha woops, Customer is from Co maybe that is where i got it from... have another set from Stan a forum member from NY we are shipping out there as well. Black cherry on his whole motor, cases, jugs, heads... with diamond cut... should be insane!
