Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
buffing paint
Old Feb 1, 2013 | 07:58 AM
jc1964's Avatar
jc1964
Stage III
Default buffing paint
i painted some parts with a rattle can. Is there a buffing compound i can use to remove the ornge peel texture with out having to wet sand?
Old Feb 1, 2013 | 10:57 AM
JRK5892's Avatar
JRK5892
i still always wet sand with 2000 wet... then turtle wax rubbing compound works great
Old Feb 1, 2013 | 11:06 AM
scottsflstf's Avatar
scottsflstf
Depending how bad the orange peel is, you should be able to buff it out pretty good. I would suggest clear coating the parts with a 2 part clear for protection from gas, weather and scratches, rattle can paint doesnt have the hardener in it that a 2 part paint does and can be easily scratched by even a paper towel.
Old Feb 1, 2013 | 11:36 AM
Notgrownup's Avatar
Notgrownup
Like JRK, 2000 grit wet dry trigger spray bottle full of water....circular motion until it is smooth, I like the 3M 3 bart compunds...works good...you might go with the 2 lighter ones since you used 2000 grit...make sure you don't sand through the clear...bufff, bufff, buff,....
Old Feb 3, 2013 | 03:11 PM
jc1964's Avatar
jc1964
Stage III
thanx for all the advise.
HardyHarHarley
Powdercoat & Paint
Dec 25, 2010 11:28 AM
KumaRide
May 27, 2010 04:51 PM
Shrug
Mar 25, 2009 11:47 PM
Brooklyn Redneck
Detailing
Aug 10, 2007 08:27 PM
imboden
Jul 16, 2005 02:45 AM
