when i paint stuff i use 2000 grit, then buff with a mico finish compound, the grit of the paper would depend on how much orange peel is in the paint. good luck and be careful!
Yea do like Mike says, I use 1600-2000 grit, use lots of water. Then use a good polish like Mcguires and buff it out. It'll look like glass when your done. I've painted a few cars and the results are great!
Gotta go with that. Remember Wet Sanding means Wet Sanding. Don't press; let the sand paper do the work; your hands just move it around. To much pressure will really wreak havoc.
You never did mention the type of paint your using?? there are quite a few types with different properties and most pain manufacturers maintain a website with pretty good instructions from prep to finish. Lots of water during the process and letting the paper do the work will result in a baby-butt smooth finish.
thanks for the tips fellas, I'll have to go out and find some of that 2000 stuff. I suppose online will be the best place to shop.....when I get it all done I'll post some pics for ya all to check out.
