Powdercoat & Paint A place to discuss everything about powder coat and paint for your Harley.
Thunder header powder coated problem.
Old Jun 7, 2013 | 08:11 PM
Todd411's Avatar
Todd411
Stage III
Default Thunder header powder coated problem.
So I decided to send my thunder header exhaust to have it hi temp powder coated. When I got it back it was more gray than black. It was flat black cause they said any gloss in the finish would burn off.
Well I installed the exhaust fired up the bike and idled it for a couple of minutes. The top front exhaust started to smoke and look shiny. Then it bubbled up a little. Any ideas on the issue? Any help is appreciated
Old Jun 8, 2013 | 05:38 PM
liquiddiet's Avatar
liquiddiet
The powder coating bubbled? Maybe it was not high temp paint or it was not cleaned properly.
Old Jun 9, 2013 | 09:44 AM
smitty901's Avatar
smitty901
Powder coat does not work on headers. Ceramic coating does.
Old Jun 10, 2013 | 11:09 AM
JRK5892's Avatar
JRK5892
Smitty i am sorry to say that is not 100% accurate... we high temp coat heaters
Todd, i am not really sure what could have happened here there are so many factors that can come into play. high temp is good though 1200* and needs to see +600* to final cure... here are some of the headers we have done in the past
whenever we do pipes/shields we are always sure to let the custom know it is at their own risk as there are way to many outside factors that come into play with pipe/shield coatings.
we do them and have had great results.
gloss high temp:
flat hight temp
tbonetony06
Dec 14, 2013 02:40 PM
wataskia2000
Powdercoat & Paint
Jan 31, 2013 02:54 PM
Collk88
Sep 1, 2012 11:19 AM
Greatscott
Powdercoat & Paint
Dec 20, 2011 12:44 PM
Razorback Rob
May 24, 2011 10:44 AM
