Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
burnt clutch?
Old Jun 20, 2016 | 07:11 AM
bobbyjoes's Avatar
bobbyjoes
Default burnt clutch?
Hi, had a friend with 15 SGS ,he had to much to drink and put it on burn out pit the last time it wont move,i imagine burnt clutch,how do you tell,will friction plates be smooth, or anything else it could be,thanks
Old Jun 20, 2016 | 11:50 AM
corliss@bakerdrivetrain.com's Avatar
It doesn't move at all? Is the belt broke? Any noise?
Old Jun 20, 2016 | 01:36 PM
bobbyjoes's Avatar
bobbyjoes
it tries to move,no noise,thanks
Old Jun 20, 2016 | 01:37 PM
soft 02's Avatar
soft 02
Drive sprocket striped.
Old Jun 20, 2016 | 01:42 PM
bobbyjoes's Avatar
bobbyjoes
you mean the big one on rear wheel?
Old Jun 20, 2016 | 01:48 PM
soft 02's Avatar
soft 02
Nope. The drive pully at the tranny. If the clutch was burnt you couldnt get it into gear and if you started in first it wouldnt release.
Old Jun 20, 2016 | 01:53 PM
bobbyjoes's Avatar
bobbyjoes
so tear it apart to make sure ,he was just going to replace clutch but have to take clutch hub off to make sure?
Old Jun 20, 2016 | 01:56 PM
soft 02's Avatar
soft 02
If he's going that far I'd do the inner primary bearing and take a look at the drive pulley.
Old Jun 20, 2016 | 02:32 PM
bobbyjoes's Avatar
bobbyjoes
thats the only way to tell too take inner primary off?
Old Jun 20, 2016 | 02:38 PM
soft 02's Avatar
soft 02
Nope. Start it in gear. If the belt doesnt turn either the splines in the pully or the clutch are fried.
