Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary Case Oil Capacity?
Old Nov 20, 2016 | 03:52 PM
Tlmanpaul's Avatar
Tlmanpaul
Stage III
Default Primary Case Oil Capacity?
I have a 2013 Road King CVO I just purchased (used with 6K miles). My manual calls for 1.4 qts. I drained at least 1.25 qts, and refilled the primary to where I could see the oil (close to it gushing out the derby cover). It took 1 qt. period. What's up? I changed from Syn3 that the dealer put in to Red Line Primary Oil. Seems to perform better (clutch is smoother). I'm guessing that the dealer overfilled it at the 5000 mile service for the previous owner?
Old Nov 20, 2016 | 04:00 PM
ROCKOUT Rocker Products
Sponsor
Are you doing this on the sidestand?
If so it'll run out way before you get the correct amount in.
For ROCKOUT information & purchasing please click the LINKS below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old Nov 20, 2016 | 04:02 PM
rkoivisto's Avatar
rkoivisto
Default Primary Lube capacity
My manual calls for 38 Oz. I always put 1 qt in. I've got 24,000 miles on my SE compensator and just took it apart. It looked like new. I also just had a inner primary seal failure and there was oil slinging everywhere. I'd say a qt is plenty.
Old Nov 20, 2016 | 07:21 PM
RedHogz's Avatar
RedHogz
The amounts given in HD manuals are for completely drained and dry components. I've always found that upon rebuild the cases have taken somewhat less than stated.
Old Nov 22, 2016 | 09:21 AM
grbrown's Avatar
grbrown
The correct procedure is to fill to the specified level, which applies to all three holes. The amounts of oil specified are for guidance only IMHO. Even on a dry build I wouldn't simply pour in the specified amount.
Old Nov 22, 2016 | 09:26 AM
ElectraJim's Avatar
ElectraJim
I just re-did my primary fluid on my bike(I had the entire primary case off the bike). I put in exactly 38 oz as my manual specifies and it didn't leak out. It was pretty close to leaking out when it was on the side stand.
Mine also calls for 38oz. I just refilled mine and it was close to leaking out when it was on the side stand.
Old Nov 22, 2016 | 07:14 PM
14GuineaPig's Avatar
14GuineaPig
https://serviceinfo.harley-davidson....386195!!1!5834
Old Nov 23, 2016 | 10:04 AM
RedHogz's Avatar
RedHogz
That's a handy link for a 2013. If I was to follow that Factory guidance, if'in I had a 2013, it would be the first time i was to remove the battery cable to check\add primary oil... And what's up with adding 7 more ounces IF you remove the inspection cover?? Does HD expect that's how much will run out when initially filled?
Old Nov 23, 2016 | 11:13 AM
14GuineaPig
Red, you might like these:
Owner's Manual
https://serviceinfo.harley-davidson....388&groupId=16
Parts Manual
https://serviceinfo.harley-davidson....697&groupId=14#
Wiring Diagrams
https://serviceinfo.harley-davidson....5526&groupId=9
The difference in primary oil amounts is because one accounts for a "dry" primary.
Old Nov 23, 2016 | 01:10 PM
RedHogz's Avatar
RedHogz
That's fantastic! I appreciate it. Happy Turkey Day..
jd05flhtci
2014-2024 Touring Models
23
Mar 13, 2016 11:11 AM
ROADKING861
Feb 6, 2012 04:14 PM
atrain68
May 20, 2011 08:04 AM
badlandr
Aug 16, 2008 07:10 PM
d42s
Sep 6, 2006 11:28 PM
