Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
2007 gasket service kit question
Old Jun 2, 2007 | 12:31 AM
harleyrobert4's Avatar
harleyrobert4
Default 2007 gasket service kit question
Today I went to Harley to pick up needed items so I can do my 5000 mile service myself. I purchased sync 3, oil filter, & a gasket service kit 1k 5k 10k, part number 17369-06. When I brought my 2007 Road King in for my 1,000 mile service I was charge for an oil o-ring part# 11105, o-ring part # 11132, clutch cover gasket part# 25416-99c, and inspection cover gasket part number 63798-99a. The numbers don't even come close and the inspection cover is sealed on the 2007 96ci. Did I get screwed on my 1k service or is thisa new kit for servicing the 2007 models?All I know is the o-rings in the kit look nothing like the 0-rings I describedprevoiusly. Any help would be greatlyappreciated.
Old Jun 2, 2007 | 07:32 AM
dawg's Avatar
dawg
Default RE: 2007 gasket service kit question
The 11105's in the kit are the same as the 11105's you were charged for (takes two o-rings, 1 tranny and 1 oil). The 25416-99C is a full derby gasket and doesn't get used on the 07's, the large o-ring does. As for the 63798-99A that's an oil filter. The 07 does not take the inspection cover gasket because there is no inspection cover because of the auto tensioner. Whoever your service writer is, they goofed! You should have also picked up two 11143 (7/16" retaining ring clips) for lubing the cables and levers/clevis pins.
tooch69
Aug 25, 2012 06:16 PM
DavTN
Oil Archive (no new posts)
Jul 18, 2011 08:07 PM
Jeff W
Jun 3, 2010 07:29 AM
Bighunter4x4
Jun 20, 2007 08:15 AM
harleyrobert4
Jun 2, 2007 01:16 AM
