Oil filter and gasket service kits
Old Aug 23, 2012 | 02:50 PM
tooch69's Avatar
tooch69
Default Oil filter and gasket service kits
i have a chrome oil filter #63798-99A and a gasket service kit #17361-05 that i purchased for my 06 road King, I just traded it up for an 08 ultra classic. will the filter and kit fit the new bike? thanks
Old Aug 23, 2012 | 03:49 PM
glide2meetu's Avatar
glide2meetu
The oil filter for sure, the gasket kit should but maybe verify with your local parts dept.
Old Aug 23, 2012 | 04:53 PM
dawg's Avatar
dawg
Part of the kit will. You can use the 25416-99C disc on the derby cover and the two 1105 o-rings. You will need a third 11105 o-ring and there is no use for the chain inspection cover gaskets. The newer model kit only includes 3 11105 o-rings and the derby cover o-ring. However, if your 08 has an accessory derby cover then you would need the 25416-99C disc gasket anyway.
Old Aug 24, 2012 | 07:01 PM
tooch69's Avatar
tooch69
Thanks for the help
Old Aug 25, 2012 | 08:54 AM
cdestuck's Avatar
cdestuck
help front the best
Old Aug 25, 2012 | 06:00 PM
Verbal's Avatar
Verbal
Interesting thing happened on my last fluid change I did on my 08 EGC. I have the stock derby cover. When I went to the dealer, he gave me the cardboard-type gasket. After reading on this board that you can use the large o-ring over I was gonna use it. When I took the derby cover off, I wiped it down and removed the large o-ring to inspect it. I gently wiped it down, and when I went to reinstall it, it wouldn't fit. It appeared to swell and would not go back into the groove of the derby cover. Glad I had the cardboard type gasket. Went ahead and used that one.
Quick question though. Can the cardboard type gasket be used over or does it need to be replaced every time the derby cover is removed?
Old Aug 25, 2012 | 06:16 PM
dawg's Avatar
dawg
I reuse my gasket a few times before replacing.
Shacky73
General Topics/Tech Tips
25
Oct 24, 2020 08:10 PM
DavTN
Oil Archive (no new posts)
Jul 18, 2011 08:07 PM
harleyrobert4
Jun 2, 2007 07:32 AM
Psycho
Aug 11, 2006 12:36 AM
fryeca
Aug 2, 2006 08:09 AM
