Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Transmission Swap
Old Aug 10, 2017 | 01:05 AM
kanders70's Avatar
kanders70
2nd Gear
Default Transmission Swap
Hey guys!.....I have a 91 Heritage softail that I want to swap out the tranny for a 98 softail tranny. Looking to do this mainly to lower rpms at highway speed. Are there any changes I need to make with the primary, compensating sprocket, starter motor etc.? or will she bolt right up? Thanks!
Old Aug 10, 2017 | 08:42 AM
corliss@bakerdrivetrain.com's Avatar
They will be a direct swap but you are trading one 5 speed for another. The ratios are still 1:1 in 5th.
Old Aug 10, 2017 | 02:09 PM
kanders70's Avatar
kanders70
2nd Gear
Thanks for your reply Mark. I also have 95 Softail Custom that at 75 or 80 mph the rpms and vibration are not near as bad as the 91. This is why I thought of doing the swap. Is there another possible contributor as to why the 95 doesn't feel maxed out at highway speeds? Thanks.
Old Aug 10, 2017 | 07:26 PM
misfitJason's Avatar
misfitJason
Gearing is why
Old Aug 10, 2017 | 08:24 PM
kanders70's Avatar
kanders70
2nd Gear
Right.......So Am I not going to achieve the results that Im wanting?
Old Aug 11, 2017 | 08:39 AM
The difference is in the primary, your 91 has a 24 tooth motor sprocket and a 37 tooth clutch sprocket. Your 95 has a 25/36 primary combo.
Old Aug 12, 2017 | 08:06 AM
TN Houndog's Avatar
TN Houndog
I don't know how much you want to spend, but if you want to fix it right let Mark fix you up with a 6 speed. You will be glad you did!
Old Aug 12, 2017 | 01:06 PM
kanders70's Avatar
kanders70
2nd Gear
I wish I could afford a DD6......just cant right now.
Old Aug 12, 2017 | 01:32 PM
TwiZted Biker's Avatar
TwiZted Biker
Can't count the times I've had guys argue that with me, a few got down right pissed off about it.
Leebert1
Jan 13, 2019 06:09 PM
Highwayman99
Dec 19, 2018 10:40 AM
Dirtdiver38
Jul 30, 2017 10:03 PM
Feb 29, 2012 11:15 PM
chad pickens
Apr 6, 2010 01:07 PM
