Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
starter idler gear
Old Nov 15, 2017 | 02:37 PM
heybaylor's Avatar
heybaylor
Default starter idler gear
I need to buy a starter idler gear for a 03 fatboy.
anyone know of a source?
Old Nov 15, 2017 | 03:16 PM
corliss@bakerdrivetrain.com's Avatar
https://www.ebay.com/itm/Spyke-Start....c100677.m4598
Old Nov 15, 2017 | 04:43 PM
heybaylor's Avatar
heybaylor
Mark tks for the link, however that one is for the pinion gear, I need the idler gear.
the one that goes between the motor shaft, and the drive clutch.
can get one with the clutch for 90 bucks, but don't need the clutch.
Old Nov 15, 2017 | 04:50 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
I the dealer doesn`t have it, you might consider a starter rebuild shop, they probably have plenty of parts donor starters...
It still looks to be available from this online HD dealer, item 26.
http://partsfinder.onlinemicrofiche....TER%20ASSEMBLY
Old Nov 15, 2017 | 11:53 PM
heybaylor's Avatar
heybaylor
thanks Dan, my local hd dealer, couldn't even understand what I wanted
Old Nov 16, 2017 | 07:27 AM
Yea all I'm seeing is starter rebuild kits.
Old Nov 16, 2017 | 04:18 PM
bustert's Avatar
bustert
http://retrocycle.com/catalogpage.php?page=279
maybe here.
what is wrong with yours?? jpeg??
Old Nov 17, 2017 | 09:08 AM
heybaylor's Avatar
heybaylor
maybe here.
thank you they show it ,however been discontinued...(my luck)
Mine has two teeth broken off..
Old Nov 18, 2017 | 07:47 AM
bustert's Avatar
bustert
worst come to worst, a machine shop can put the teeth back on.
Old Nov 18, 2017 | 07:18 PM
Dan89FLSTC's Avatar
Dan89FLSTC
This is a common automotive starter we are discussing, not a one of a kind unavailable unit...
A starter shop will have a scrap pile of these starters, and it will be easy to find a usable gear...
