Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Clutch keeps burning out
Old Jun 17, 2018 | 12:34 PM
NcPokerKing's Avatar
NcPokerKing
Stage I
Default Clutch keeps burning out
Just got a 1200 sportster 2009 with only 5k miles on it an i burnt the clutch up on the hour ride home i got a new one installed an did alot of research on how to properly use the clutch an still after 2 days of riding it alot it happened again lost power going up a hill an now its burnt out again i guess what would make this happen im at a loss of words im sad lol i wanna ride my harley
Old Jun 17, 2018 | 06:44 PM
bustert's Avatar
bustert
several things come to mind
proper throw out adjustment
spring plate (most get rid of it with an extra plate setup)
spring disk weak
clutch stack height
warped plates
binding in the keyways hub or shell
wound up cable
proper cable end play
please describe condition of plates when removed bluing of the steels friction material wear, burnt smell maybe even a jpeg.
Old Jun 17, 2018 | 08:53 PM
nevil's Avatar
nevil
Sounds like a case of abuse, not saying it's intentional. It's nice that you researched how to use a clutch, but you really should take a rider's course.
Old Sep 11, 2024 | 01:26 PM
Shilohw1's Avatar
Shilohw1
New Member
Default Nice try
Nice try. I'm having the same problem and I've had it replaced twice. Shouldnt happen that soon. Never had a bike it did happen to. Ive known how to ride for 10 years. Guys I ride with abuse their bikes, I don't. Something else is going on, and if you're not able to figure it out please don't comment. Harleys aren't hard to ride and clutches don't burn out over a few miles, thanks.
Old Sep 13, 2024 | 12:42 PM
RDHIGH's Avatar
RDHIGH
- you know how to ride- now its time to learn to wrench. Harleys arent hard to ride, and they arent hard to work on either. Get a manual and figure it out yourself, you will find it very satisfying. have fun!
Old Sep 13, 2024 | 12:56 PM
jake24lt's Avatar
jake24lt
3 things come to mind.
extremely weak clutch spring (s)
clutch adjustment way off, as in, no free play in the lever so as to have the clutch never really grab they way it was designed.
Operator error.....Experienced, standard shift anything operators, know when a clutch is slipping. and smart ones back off, down shift or figure out why, before total failure.
Old Sep 13, 2024 | 01:16 PM
Chris_G's Avatar
Chris_G
Old Sep 13, 2024 | 09:24 PM
Max Headflow's Avatar
Max Headflow
If you are doing everything right as far as adjustment goes and the pressure plate spring is plenty strong then I think that the clutch pack stack up is off and the pressure plate is running out of travel. Without enough travel, the pressure plate can't put pressure on the clutch pack.
Old Sep 14, 2024 | 04:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Please start your own thread.
stockglock1927
May 17, 2014 05:11 PM
IronHeadDrew
Custom Models
Jun 27, 2013 09:17 AM
BM05FLHT
Jan 19, 2013 12:38 PM
Sam07
EVO
Jul 14, 2011 12:14 PM
jcarson
Ironhead
16
Apr 26, 2008 01:48 AM
