Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
1973 shovalhead clutch question
Old Aug 12, 2018 | 06:57 PM
mirage14048's Avatar
mirage14048
Stage II
Default 1973 shovalhead clutch question
Hello I am new to site I have a question I just took a 1973 shovalhead in trade , just changed oil and I was wondering is this bike a dry clutch system or wet ? There is only a very little oil in primary case just barely covers bottom should there be more ? I have the manual but it's missing a couple pages so I couldn't tell what setup I have but then again I'm 65 years old maybe not reading it right ,it runs great just thought I would change oil to be on safe side not knowing when previous owner did . Thanks in advance for any help.
Old Aug 12, 2018 | 09:03 PM
bustert's Avatar
bustert
clutch should be wet unless someone changed it. what info are you missing? might have a pdf in the library. i had a 1974 fxe with manual foot added with andrews 1 & 3 , run like a scalded dog,
Old Aug 13, 2018 | 04:32 AM
grbrown's Avatar
grbrown
My 1974 FX, bought new, was dry clutch. The primary is dry-sump, meaning that engine oil is fed to the chain, then pumped back out. It can be a challenge to keep the chaincase air-tight, so the oil doesn't build up and smother the clutch! It is also not unusual for owners to delete the oiling system and go to a wet clutch, although I managed to keep mine as original.
Old Aug 13, 2018 | 09:41 AM
bustert's Avatar
bustert
yep, mr. brown is correct, seems my brother-in-law went to wet as he had issues with oil getting onto the plates. i remember working on it as i bought it from him and saw wet. my pan was dry. my bad since i still have the service info, thanks for the correction!
Old Aug 13, 2018 | 12:26 PM
mirage14048
Stage II
Default Missing the pages from manual
I took the bike in on trade for a car I sold, the guy I got it from gave me original 1973 manual , I am missing the pages that explain the clutch info like is it a dry setup or wet , I did change the oil and looked in primary first and there is barely enough oil to cover bottom of primary , I was under the impression that there should be enough oil to reach bottom of clutch assembly. There is that little oil on bottom of primary so I was assuming it’s a wet setup
krusty1
May 9, 2013 08:49 PM
Bama91
EVO
Oct 15, 2012 10:52 AM
biczeq
Shovelhead
Sep 6, 2012 08:03 PM
Lou G
Mar 13, 2011 04:02 PM
Timboto
Shovelhead
Aug 28, 2007 10:13 PM
