Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Question about motor sprocket
Old Jul 27, 2020 | 02:28 PM
penmaker's Avatar
penmaker
Default Question about motor sprocket
I've got a question that I think I know the answer to, but wanted opinions from people who know more than me. This is not a debate on compensator vs solid. If I put a solid motor sprocket on and went a different teeth count, would I need to calibrate the speedometer? I'm thinking not since the speed sensor is on the transmission and that's not changing. What do the experts of HDF say?
Old Jul 27, 2020 | 05:59 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Actually it does matter.
Changing the motor sprocket size changes the ratio between the crankshaft and the transmission...
Old Jul 27, 2020 | 09:35 PM
ahern25's Avatar
ahern25
From my understanding if you change it at the motor sprocket then no need to change the speedometer. If you change the transmission pulley, or rear wheel pulley then yes.
Old Jul 28, 2020 | 09:50 AM
penmaker's Avatar
penmaker
But would that change the speedometer calibration?
Old Jul 28, 2020 | 10:15 AM
Max Headflow's Avatar
Max Headflow
Changing the primary sprockets won't effect the speedo reading but if you have a later 6 speed with will effect any gear indicator you have.
Old Jul 28, 2020 | 12:25 PM
penmaker's Avatar
penmaker
Is the gear indicator a combination of engine rpm and ground speed?
Old Jul 28, 2020 | 12:55 PM
Max Headflow
Well sort of.. It compares engine RPM to vehicle speed measured at the gearbox. That ratio changes when you change the primary gearing.
Old Jul 28, 2020 | 01:27 PM
ahern25's Avatar
ahern25
What year bike, model, and what is it you are looking to accomplish?
Old Jul 28, 2020 | 05:08 PM
penmaker's Avatar
penmaker
2014 Limited. I'm thinking about replacing my compensator with the Darkhorse sprocket and going with the 32 tooth for a little more low end.
Old Jul 29, 2020 | 12:42 AM
ahern25's Avatar
ahern25
Got it. I've never made that change, but have heard good things that compensator. If you go through with it please come back and give us some feedback and thoughts about it. Good luck.
