Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
6 speed swap
Old Jun 30, 2021 | 06:36 AM
taube0dahkota@gmail.com's Avatar
Default 6 speed swap
I have a 2005 road king with the 5 speed transmission. What do I have to do to swap it out with a 6 transmission?
Old Jun 30, 2021 | 06:50 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Use an aftermarket gearset that is designed to work in a 5 speed case.
Old Jun 30, 2021 | 07:47 AM
I know baker makes one but does anyone else? Are they better than swapping out the transmission?
Old Jun 30, 2021 | 09:39 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Not sure what companies are making 6 speed gearsets for 5 speed cases anymore, I have never used one.
I`m a fan of the original equipment 5 speed unit, which is a great transmission.
You are not going to be swapping an entire transmission to go to a six speed, you will need to replace the gearset in your transmission case.
Old Jun 30, 2021 | 10:09 AM
Max Headflow's Avatar
Max Headflow
Besides Baker, HD makes an SE 6 speed for the 5s. It might be a Jims. Jims also makes one or used to. Ultima is another.
I'm with Dan tho. Might use a 6 speed in a big motor evo softail tho.
Old Jun 30, 2021 | 12:49 PM
I could have swore I read somewhere that you could swap the whole thing
Old Jun 30, 2021 | 12:50 PM
My motor definitely isn’t stock. I know that extra gear would be nice cruising down the interstate.
Old Jun 30, 2021 | 12:56 PM
Dan89FLSTC's Avatar
Dan89FLSTC
You can buy an entire transmission from Baker, but it will cost more than your bike is worth...
Old Jun 30, 2021 | 02:23 PM
Max Headflow
Has the motor been stroked?
Old Jun 30, 2021 | 08:12 PM
I went as big as I could without having to stroke it
