Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary Chain tension specs
Old Aug 5, 2007 | 12:21 PM
Daves 883r's Avatar
Daves 883r
Stage II
Default Primary Chain tension specs
Can anyone tell me what the proper chain tension is suposed to be on the 06 883 evo ? I am having some noise down there and want to cover the bases before i go for help at the dealer. May be clutch related is there a proper adjustment for that also? Thanks.
Old Aug 7, 2007 | 01:37 AM
enternetic's Avatar
enternetic
6th Gear
Default RE: Primary Chain tension specs
1/4 inch play is a good rule of thumb.
check out:
www.expertvillage.com/videos/motorcycle-primary-one.htm
Bearcat1
11
Nov 1, 2013 08:43 AM
SecondChance!!
May 15, 2011 06:49 PM
jpb146
Jan 24, 2011 11:43 AM
cecharles
Oct 27, 2010 10:55 AM
vernfindley
Oct 18, 2007 06:54 PM
