Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Cluctch won't disengauge after cable install!
Old Dec 14, 2005 | 06:20 PM
2002fxstb's Avatar
2002fxstb
6th Gear
Default RE: Cluctch won't disengauge after cable install!
It is always in gear. When i pull in the clutch, i cant move it or if I try to start it in gear, it lunges forward.
Old Dec 14, 2005 | 06:22 PM
LAF's Avatar
LAF
Did you adjust the clutch? I know someone asked this already, but I don't think I saw your answer? If you adjust your cable adjusters for plenty of slack, do the clutch adjustment, loosen nut, turn center adjuster to you feel it touch, back off 1/2 to 1 full turn based on your "gray" clutch area you prefer, pull the clutch lever once or twice, adjust cable adjust for 1/16 to 1/8" space at the ferrule (where the cable hits the handle) and you may need to pull back on the cable to see how much slack you truly have at the ferrule to handle. It really should be that easy. Too long a cable would have done nothing as even 2" over, I don't think there is that much adjustment in the cable adjusters.
If you have done the clutch adjustment, then it must be on the install somewhere or an act of the Harley Gremlins that just is coinciding with your install.
Old Dec 14, 2005 | 06:29 PM
LAF's Avatar
LAF
Have you rocked the bike forward and backward and trying to find neutral without the clutch, not too awful bad in this case to at least see if you can click it int neutral. It will not hurt it to do this but you MUST rock the bike forward to take the pressure off everything.
Old Dec 14, 2005 | 07:27 PM
pilot1996's Avatar
pilot1996
Check this link:
https://www.hdforums.com/m_70839/tm.htm
I used it and it worked great.
One last question, did you compare the two cables (original and new) side by side? Did you ensure that the travel length is the same? This is what is important...extra length elsewhere is not a problem...the travel length is the real issue...
If the instructions in the link I gave you don't work, lay the two side by side and see what the difference in travel length is...
Pics might help too...
We'll get you through this...
Correct me if I'm wrong, but I think your clutch is always DISengaged...
Mac
Old Dec 14, 2005 | 09:54 PM
2002fxstb's Avatar
2002fxstb
6th Gear
I have adjusted, un-adjusted, put the bike in first gear, taken it back to neutral, checked, double checked and some other check with the service manual. Nothing appears to be out of the norm. So... since i have been having so much fun with this situation as of late, one of the mechanics stopped by and took a look at it on his way home. His conclusion, something internal is F***** Up. We went thru the adjustment process again, removed the cover and checked the linkage. He said that everything looks just like it should and it should be just that easy. Anyway, they are coming to get it tomorrow to find out what is wrong.
Old Dec 18, 2005 | 04:23 PM
billvaughn's Avatar
billvaughn
Please let us know what the outcome was.......
deez nuts
Apr 23, 2017 10:48 PM
mitchxc700
Jun 23, 2013 03:20 PM
machm1969
May 7, 2013 05:00 PM
HWill
Feb 24, 2013 09:26 PM
jamieg101
Apr 12, 2012 12:17 AM
