Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
hard to find neutral
Old Nov 19, 2007 | 09:30 PM
guy10's Avatar
guy10
Default hard to find neutral
I had my bike in for warranty work , I had some teeth break in the ring gear and starter drive so they had to put a new clutch assembly in , I now find it hard to get the bike into neutral , it wants to jump into 2nd or back to 1st it takes several trys to get it in . Just wondering if itcould be the cable tension.
Old Nov 19, 2007 | 10:52 PM
lilmike9's Avatar
lilmike9
Default RE: hard to find neutral
Sounds like it could be the clutch adjuster screw. That's in your primary. I found that a good adjustment is 1 1/4 tunrs out from snug.
Old Nov 22, 2007 | 07:53 AM
dog155's Avatar
dog155
Could also be the primary chain not adjusted right.Call the dealer.
Old Nov 22, 2007 | 08:50 PM
BillyO's Avatar
BillyO
My vote is for a loose P chain.
Old Nov 24, 2007 | 07:43 AM
Leadfoot's Avatar
Leadfoot
If the clutch seems to release rather close to the fully squeezed position, it is probably the clutch adjustment. You might be able to take up the slack at the cable adjustment. If not, the clutch will need adjusting. Make sure the bike is warm also, cold primary fluid will do the same thing. Ride it awhile, as a new clutch needs breaking in, and it may just be breaking in. If you are not happy, I think I would first call the dealer and allow them to fix it. Should not cost you a penny. Plus, if one of the techs is doing **** poor work, they need to know it!
arod6
Feb 18, 2015 10:47 PM
WP50
EVO
Jun 22, 2011 12:31 PM
Jmarcher
Feb 22, 2011 05:29 PM
jgoshow
EVO
Apr 19, 2010 07:11 PM
Ace2000
Jun 20, 2009 08:06 PM
