Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
AMSOIL SEVERE GEAR 190
Old May 1, 2008 | 10:43 PM
NEONNIGHT34609's Avatar
NEONNIGHT34609
Default AMSOIL SEVERE GEAR 190
I hsve an 06 bob and live in florida where its HOT .. has anyone used the new 190 amsoil on there tranny ? i think i am going to try it unless i hear something negitive here about why its not good .. thanks
Old May 4, 2008 | 08:23 PM
tobyhd1's Avatar
tobyhd1
Default RE: AMSOIL SEVERE GEAR 190
Give us your report when you have afew miles on it.I would like to know.Toby
Old May 5, 2008 | 10:37 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Service Life
AMSOIL Severe Gear Synthetic SAE 190 and SAE 250 Gear Lubricants are intended for severe racing and other applications where extended drain intervals are not beneficial.
I would use the 75w110 or 85w140 if I were you. That oil is for drag racing differentials where it gets changed out all the time.
Old May 6, 2008 | 07:14 AM
NEONNIGHT34609
where did you read that ? know alot of people are using redline and its the same weight
Old May 6, 2008 | 08:13 AM
johntheone's Avatar
johntheone
Sounds like good extreme stress oil, personally I would have though it to specialist for use in a Harley - not exactly the most stressful environment. If your going to give it a go - check regularly, be prepared to change to something less exotic.
http://www.amsoil.com/StoreFront/srn.aspx
APPLICATIONS
AMSOIL Severe Gear Synthetic SAE 190 and SAE 250 Gear Lubricants are excellent for severe differential applications, including off-road truck racing, rock racing, rock crawling, tractor pulling, funny car racing and dragster racing. Other severe duty applications include heavy duty trucks and equipment where increased lubricant film is necessary. These oils are recommended for use in hypoid gear differentials and other applications requiring a high viscosity, API GL-5 gear lube. Where limited slip performance is required, use AMSOIL Slip-LockÂŽ limited slip additive.
Service Life
AMSOIL Severe Gear Synthetic SAE 190 and SAE 250 Gear Lubricants are intended for severe racing and other applications where extended drain intervals are not beneficial. AMSOIL recommends changing the lubricant as conditions dictate. Where extended drain intervals are desired, AMSOIL recommends monitoring by oil analysis.
Old May 10, 2008 | 09:56 AM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
I use Amsoil Severe Gear 75 / 110 synthetic oil. Been using it for years. I had a 1990 Ultra Classic with with 170k on the bike. First transmission went at85k due to a failure in the trans case. The second transmison is still going with 90k. Good stuff.
I also runAmsoil MCV 20w 50 synthetic motor oil in my motor. Its costs more, but in the long run it will be the best way to go
Old May 10, 2008 | 03:21 PM
Heath's Avatar
Heath
Former Sponsor
Not saying it won't work, but seems a little overkill. The MCV oil or the 75W-110 gear lube have the viscosity range that is recommended by HD. There are added "tackifiers" in the 190 and 250. I don't have any on the shelf but I believe this stuff also comes in a green color, just FYI.
Old May 10, 2008 | 07:45 PM
tobyhd1's Avatar
tobyhd1
The earlier Series 2000 75w-90 also had the greenish/blue tint.Toby
Old May 10, 2008 | 08:29 PM
KBFXDLI's Avatar
KBFXDLI
ORIGINAL: NEONNIGHT34609
Amsoil website. Use the 75w110 you will really like it. FWIW Redline is not the sam weight.
Old May 14, 2008 | 02:06 AM
joe joe's Avatar
joe joe
Stage III
lost
20monster07
Sep 1, 2010 08:13 AM
EZ48
Jun 23, 2009 06:56 AM
bigbean78
May 8, 2008 06:57 AM
brock161
Oil Archive (no new posts)
Jul 10, 2007 04:06 PM
