Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Chain tensioner
Old Mar 11, 2005 | 11:58 PM
hawk's Avatar
hawk
Default Chain tensioner
Has any one installed a hydraulic primary chain tensioner On an 88 engine? I have an 01 Heritage and I am considering installing one,Where can they be purchased? what kind is best? How hard is the install?Forgive the dumb questions from the old guy.
Old Mar 12, 2005 | 12:03 AM
igniter's Avatar
igniter
Default RE: Chain tensioner
I don't know about the hydraulic one. But I know someone who has the spring loaded one. Under normal riding it works just like it is supposed to. But under extreme riding it can be pushed down by the chain allowing the chain to jump a tooth. Most of us wouldn't have this problem, but then again most of us don't ride like the guy I'm talking about. Anyone else?
Old Mar 12, 2005 | 12:10 AM
Scout's Avatar
Scout
J&P. Take the shifter, board and outer primary off. Make sure you have a gasket. Easy install, just follow the package instructions. Check your chain, clutch, starter jackshaft and gears while you have the outer off. Check the rear shifter linkage behind inner primary while you have it apart, since it's a big job if it's loose and you already have 1/2 of it apart. Same for drive belt. Make sure you torque it back right. Pretty easy job, about 2-3 hours.
Old Mar 12, 2005 | 01:17 AM
hawk's Avatar
hawk
Thanks Joe,Will this eliminate the adjustments?
ORIGINAL: Joe Scout
Old Mar 12, 2005 | 01:27 AM
Scout's Avatar
Scout
Yes, you don't need a hydraulic, a spring one will work fine. Personally, I would not put one on unless you had to pull the outer primary for another reason. It's not a bad idea to manually check your chain and clutch every time you change your oil. Automatic adjusters make you lazy, and you may miss an obvious problem if you don't look into the chain and clutch case every once in a while. Just my opinion.
Old Mar 12, 2005 | 01:50 AM
hawk's Avatar
hawk
You are right,I tend to get lazy when I know better,I will take your advice. Thanks
ORIGINAL: Joe Scout
Road Ranger
May 16, 2015 08:06 PM
StrikeZone
Mar 5, 2013 01:42 PM
fulldraw00
Jun 22, 2011 06:32 PM
Ramboamt
Jan 18, 2009 10:41 PM
harris48cars
Jun 16, 2006 09:53 PM
