Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Metal on primary drain plug
Old Sep 18, 2008 | 06:10 PM
wideopen1967's Avatar
wideopen1967
Default Metal on primary drain plug
I have a 07 Road King at 10000 miles I changed all oils. When draining the primary I found what I would consider an excessive amount of metal on the drain plug. Refilled and added oil ran bike 1 day. Drained oil, same excessive amount of metal on plug, just drained oil third time today after a week of riding 140 miles, same thing, metal shavings on plug. The bike is not making any noise, clutch is working fine.
Any ideas?
Old Sep 18, 2008 | 06:48 PM
rbabos's Avatar
rbabos
Time to pull the outer primary and look at the sprocket teeth and chain. Only other areas would be the ring gear, starter teeth and inside the comp, as in cam ramps and pockets in the gear. It should be obvious if there is that much wear particals.
Ron
mjrobinson
Oct 11, 2012 06:23 PM
freebyrd
Jun 6, 2011 05:50 PM
usmcbay
Nov 7, 2009 09:37 PM
mike_oh
Feb 24, 2008 09:05 AM
Z
Aug 21, 2007 09:45 PM
