Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
Primary oil change
Old Apr 27, 2006 | 01:52 AM
Inferno00's Avatar
Inferno00
Default Primary oil change
I just changed my primary oil today when I installed my new chrome outter cover. When I drained the old oil it was brown and looked just like engine oil. The bike shop that I bought my supplies from gave me BelRay transmission oil which is red. Was this the right oil??? I called the shop and they said it was, but I'm kind of skeptical. Thanks.
Old Apr 27, 2006 | 01:56 AM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: Primary oil change
Yes, that is the correct oil.... If you had Redline, you would be using MTL, which is ATF as well (and it is Red as well)...
Old Apr 27, 2006 | 02:01 AM
Inferno00's Avatar
Inferno00
Thanks for the response. It looks like (in all of my wisdom) I stripped the threads of the crankcase today when I was draining the oil. The plug seems to be fine, but the actual threaded hole is what is stripped. Have any ideas on how to fix that?
Old Apr 27, 2006 | 02:05 AM
Shovelhead Bob
Trying to figure out how you did that.......
Too much cranking on it, or cocked drain plug....
Did you completely pull the threads out of the pan???
Try to repair the threads first... If that fails, then you will need to go plus size on the plug...
Old Apr 27, 2006 | 03:54 AM
Inferno00's Avatar
Inferno00
I'm pretty sure it was a cocked plug. Not too bright...... I'll see what I can do with the threads first. Thanks again.
------Sometimes it's easier to ask for forgiveness, than it is to ask for permission.------------
Old Apr 27, 2006 | 04:31 PM
BluegrassBuck's Avatar
BluegrassBuck
Which bike do you have? You didn't remove the plug in the crankcase did you?
Old Apr 27, 2006 | 04:55 PM
vernh59's Avatar
vernh59
[sm=smiley19.gif]
Old Apr 28, 2006 | 02:10 AM
Inferno00's Avatar
Inferno00
Ohhhhh mannnn!!!! It gets even better. The plug's fine. The hole's fine. The crankcase is cracked. There's a hairline crack in the crankcase from the lip of the threads upwards... The bike is now at a shop where they're going to weld the crack and hole closed. I've changed the oil on hundreds of cars, but I've never had this much trouble..... Who would have thought that you could break the motor while changing the oil?????
Old May 1, 2006 | 12:57 AM
wfokendall's Avatar
wfokendall
6th Gear
I run a Revira Pro Clutch and they recommend Dexron III fluid in the Primary. Just an FYI.
deadanal
Oil Archive (no new posts)
Aug 29, 2012 10:19 PM
HDGent
Jun 30, 2011 08:30 PM
roadgliderick
Jan 12, 2011 01:18 AM
crazyeight
Apr 14, 2010 09:45 AM
huntinjoe
May 21, 2007 12:19 PM
