Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
primary knocking
Old Aug 26, 2009 | 09:10 AM
dougdahead147's Avatar
dougdahead147
Stage I
Default primary knocking
Ok i have a 09 1200 nightster. and if i am moving in 1st gear and pull the clutch in and continue to coast at about 2-3 mph and then let the clutch out again (usually when i let it out slow) to start moving, a knocking noise seems to be coming from the primary. sometimes just one knock sometimes two or three. i noticed it after i changed the primary fluid. (used whatever the dealership uses). clutch was adjusted too both at cable and under derby cover. dealership said its normal but no other bikes seem to do it. any ideas.
Old Aug 26, 2009 | 02:40 PM
Saen O'Neill's Avatar
Saen O'Neill
Stage IV
Hey have you checked the compensator sprocket and housing, especially the nut. Mine came looses and $600.00 later I was advised this problem has been addressed by HD mechanics involving improper torque settings. I'm not a pro but I heard the same noise, couldn't find the source and two days later, WHAM. Good luck
elevenbravo78
EVO
Dec 18, 2025 07:42 AM
watindes
EVO
29
Aug 9, 2013 07:36 PM
rockajet1
Apr 20, 2013 10:29 AM
GPHDXLC
Aug 23, 2012 12:58 PM
2006ultra
Jun 18, 2012 08:31 PM
