Primary/Transmission/Driveline/Clutch Find answers to general powertrain, primary and transmission. Have clutch issues and need suggestions? Post them here.
5 gear making noise
Old Sep 13, 2009 | 12:21 PM
deadshot's Avatar
deadshot
Default 5 gear making noise
I have a 2007 street glide with 5000 kms on it, in 5 gear it get a howl but not in any other gear. anyone else have this same problem? what was it?
Thanks
Old Sep 13, 2009 | 07:17 PM
dontdropit's Avatar
dontdropit
Active Streak: 30 Days
Active Streak: 60 Days
It's normal, we all have it to some degree. You can install the IDS pulley system and or run a nice synthetic gear oil and it will reduce the noise.
Old Sep 13, 2009 | 08:00 PM
dawg's Avatar
dawg
In the 6 speed transmissions, 5th gear always sounds a littly "whiny." It is the difference between the helical cut and straight cut gears. 1st and 5th gears are straight cut gears and the 2,3,4, and 6 gears are helical cut. It was done for longevity reasons as 5th gear is going to be used more than 6th unless on the open highway, but does make it a bit noisier. They changed the 5th gear in the 2010 tranny's due to people complaining about it.
Old Sep 14, 2009 | 06:10 PM
WildBill2566's Avatar
WildBill2566
For some reason I thought 3rd and 5th were straight cut gears, I will check the parts manual.
Straight cut gears are stronger, yet HD changed them due to people complaining, I'd rather have stronger myself, go figure.
Old Sep 18, 2009 | 10:17 PM
oct1949's Avatar
oct1949
Nope its 1st and 5th.
Old Oct 29, 2009 | 06:08 PM
Eddy09FLHTC's Avatar
Eddy09FLHTC
Stage I
Default 1st Gear too??
I noticed the whistling noise in 1st gear too, is this the same type of noise? if I throttle up to 15-20 mph and release the throttle without shifting up to 2nd and clutch released I hear a rather load whistle.
Old Oct 29, 2009 | 06:56 PM
prodrag1320's Avatar
prodrag1320
just the JIms 6 speed,HD should have had baker make them
kirby
Port Dawg
Mar 21, 2013 02:02 PM
automan
Aug 4, 2012 01:18 PM
Clint55
Mar 4, 2010 07:06 AM
Lindsay227
Sep 13, 2009 07:23 PM
frisco42
Oct 24, 2006 01:24 AM
